[GRASS-user] Grass70 wxgui vs. command line d.*
John A Stevenson john.stevenson at manchester.ac.uk
Tue Dec 8 12:58:40 EST 2009
Hi all,
I've been using GRASS on a Linux machine for about 18 months now, and
have been following the recent '[GRASS-user] grass70 and display
monitor' thread with interest.  I have put together some of my thoughts
in the hope that they are useful.  Many are similar to what others have
said, but these are things that are most important to the way that I use
grass.
Advantages of command line:
- it is VERY quick once learned
- easy to write scripts
- can work remotely from slow computer over ssh -X connection
- interaction with operating system commands and other software e.g.
imagemagick, GMT
- full history of what has been done
- easy to repeat previous commands
Reasons that I use the mouse:
- d.zoom
- d.what.rast, d.what.vect
- v.digit
- d.profile
Reasons that I use the wxGUI
+ wx version of v.digit.  Especially being able to see and alter table
attributes, and to take features from background maps.
+ wx profile tool
+ Easy changing of map element colours, transparency etc
I hadn't previously realised that you could use d.rast on the wxPython
command line, so I tried it out quickly on a fresh build.  Initial
thoughts are:
wxGUI command interface advantages:
+ Timestamps on when commands were run
+ Lists of options taken by commands given as you type
Dislikes of wxGUI command interface:
- Warning message when typing 'd.rast mymap' instead of 'd.rast map=mymap'
- Annoying delay (1-2 seconds) between typing a command and anything
happening
- No d.erase implemented yet
- The command line doesn't clear after each command
- No scrolling through past commands
- History of GUI terminal not synced with main terminal history
- Can't pipe or redirect output from terminal commands e.g. 'v.db.select
mymap > data.txt'
- Can't pipe or redirect output from 'Query raster/vector maps'
Thoughts:
- It seems like the wxGUI command line will never be as functional or
fast as a normal shell.
- I agree with Hamish's suggestion that including an autorefreshing
image viewer would be very helpful.
- I agree with Dylan Beaudette that a short script (d.quickview?) could
be included that sets up all the environment variables and temporary files.
- I will use the wx version of v.digit and d.profile from now on.  I can
also use the gui to set the region.
- That still leaves the issue of d.what.* (as Markus Neteler wrote).
- And of working over slow ssh connections.
Cheers
John
p.s. Is there are new version of Open Source GIS - a GRASS Approach
planned to cover the different way of working in Grass7?
Dr John Stevenson
Postdoctoral Research Associate
School of Earth, Atmospheric and Environmental Sciences
Williamson Building (Room 2.42)
University of Manchester
Manchester M13 9PL, UK
tel. +44(0)161 306 6585; fax. +44(0)161 306 9361;
