[GRASS-user] Flakiness under OSX
Michael Barton michael.barton at asu.edu
Wed Dec 9 10:41:49 EST 2009
I'm not using the TclTk interface but have had no problems at all with
GRASS 6.4 on the Mac with 10.5.8.
Have you updated to William Kyngesburye's current frameworks?
As long as you have not installed any separate versions of Python you
don't need to sort out anything to run the wxPython GUI. You already
have Python 2.5.1 and we are now distributing GRASS with the needed
version of wxpython included. William's binaries should work fine in
this regard. You can also download one of my unofficial builds at...
http://www.public.asu.edu/~cmbarton/files/grass_mac
Michael
On Dec 9, 2009, at 3:02 AM, grass-user-request at lists.osgeo.org wrote:
> Date: Wed, 09 Dec 2009 17:29:10 +1100
> From: Richard Chirgwin <rchirgwin at ozemail.com.au>
> Subject: [GRASS-user] Flakiness under OSX
> To: grass-user at lists.osgeo.org
> Message-ID: <4B1F43B6.3050904 at ozemail.com.au>
> Content-Type: text/plain; charset=ISO-8859-1; format=flowed
> Does anyone else experience UI crashes using Grass 6.4.0 RC5 under OSX
> 10.5.8?
> In particular:
> 1. TCL-TK can often hang on an attempt to resize the map window.
> 2. Segfaults under v.digit
> I realise I should be using the python interface by now, but I don't
> really have time to sort out the python versions at this stage ...
> Richard C
