[GRASS-user] Re: Problems displaying d.vect.thematic
Omar Bautista González omarbautistag at gmail.com
Wed Dec 9 17:24:48 EST 2009
I tested, the same command on an older version of GRASS and it worked
(6.2.3). So I think this is a bug on this recent version (6.4.0RC5).
I also tried simpler commands with d.vect.thematic and didn't worked
with 6.4.0RC5. These commands worked well on 6.2.3.
¿What can we do to solve this module? I'm not programming on C now. If
I would I'll try to figure out some changes on d.vect.thematic module.
Att.
2009/12/7 Omar Bautista González <omarbautistag at gmail.com>:
> Hello:
> The problem is with the d.vect.thematic command. It don't display
> nothing on the monitor. Even when other commands do it right.
> I did the following commands:
>> d.mon x0
>> d.vect.thematic -s map=JCE_M2006 type=area column=RD_ALIANZA  layer=1 icon=basic/circle size=5  maxsize=20 nint=4 pointcolor=255:0:0  linecolor=0:0:0 startcolor=255:0:0 endcolor=0:0:255  themetype=graduated_colors monitor=none  themecalc=interval colorscheme=blue-red;
> And nothing is displayed. Here are the output errors:
> Segmentation fault
> Thematic map legend for column RD_ALIANZA of map JCE_M2006
> Value range: -
> Mapped by 4 intervals of -inf
> Color(R:G:B)    Value
> 0:0:255          -
> DBMI-DBF driver error:
> SQL parser error: syntax error, unexpected AND processing 'and'
> in statement:
> SELECT cat FROM JCE_M2006 WHERE RD_ALIANZA >=  and RD_ALIANZA<=
> Error in db_open_select_cursor()
> 85:0:170                 -
> in statement:
> SELECT cat FROM JCE_M2006 WHERE RD_ALIANZA >  and RD_ALIANZA<=
> 170:0:85                 -
> in statement:
> 255:0:0          -
> in statement:
> I installed ubuntu 6.10 on a Dell Mini 10. Then from the repositories
> I installed GRASS 6.4.0RC5.
> This is very strange because other commands are displaying well. Like
> the following:
> d.vect.chart map=PuntosCentralesM2006
> type=point,line,boundary,centroid  layer=1
> columns=C_PLD,C_PRD,C_PRSC,C_OTROS  ctype=pie ocolor=black
> sizecol=P_OTROS size=15 scale=1 colors=purple,white,red,yellow;
> I tried also with the GUI having the same problem.
> Regards,
> - Coordinador de Investigación para el Desarrollo,
> Diseño, Monitoreo y Evaluación
> Visión Mundial República Dominicana
