[GRASS-user] g.region (was v.to.rast conversion)
Rich Shepard rshepard at appl-ecosys.com
Thu Dec 10 11:06:31 EST 2009
On Thu, 10 Dec 2009, Giacomo Piva wrote:
> To clarify my problem, i want to specify that the main problem is that all
> command that involves the g.region always returns the reported error
> (ERROR: default region is not set.) also the "help".
Giacomo,
   If you did not set the region/boundary when defining the location and
mapset you'll see this error. Have you tried 'g.region vect=<mapname>'? That
sets the region to that of the imported vector map. You can also use the
rast= option to set the region based on a raster map.
Rich
