[GRASS-user] Compiling GRASS 6.4.0RC5 on AIX 5.3
Mike Waldron mwaldron at email.unc.edu
Fri Dec 11 14:14:12 EST 2009
I have gotten the configure to run successfully. Here is a portion of
the make that has a failure. It is in a library so this obviously has a
cascading effect of causing many other modules to fail to compile.
make[4]: Entering directory
`/afs/isis.unc.edu/pkg/grass-6.4.0/.build/rs_aix53/grass-6.4.0RC5/lib/gis'
make[4]: `OBJ.powerpc-ibm-aix5.3.0.0' is up to date.
make[4]: Leaving directory
xlc_r -q64
-I/afs/isis.unc.edu/pkg/grass-6.4.0/.build/rs_aix53/grass-6.4.0RC5/dist.powerpc-ibm-aix5.3.0.0/include
-I/afs/isis/pkg/libpng/include -I/usr/loca
l/include -I/opt/freeware/include -I/usr/lpp/X11/include/X11
-I/usr/include -I/usr/include/fontconfig -I/usr/include/X11
-I/usr/include/X11/Xft -I/usr/incl
ude/X11/ext -O -qstrict  -I/usr/include -I/usr/include/fontconfig
-I/usr/include/X11 -I/usr/include/X11/Xft -I/usr/include/X11/ext
-DPACKAGE=\""grasslib
s"\" -D_FILE_OFFSET_BITS=64 -DGDAL_LINK=1 -DGDAL_DYNAMIC=1
-DPACKAGE=\""grasslibs"\"  -I/afs/isis/pkg/proj/include
-I/afs/.isis/pkg/gdal-1.6.2/include -I/
-o OBJ.powerpc-ibm-a
ix5.3.0.0/zone.o -c zone.c
/afs/isis.unc.edu/pkg/grass-6.4.0/.build/rs_aix53/grass-6.4.0RC5/ldAix
/bin/ld -bhalt:4 -bM:SRE -bE:lib.exp -H512 -T512 -bnoentry -b64 -o
/afs/isis.unc.edu/
pkg/grass-6.4.0/.build/rs_aix53/grass-6.4.0RC5/dist.powerpc-ibm-aix5.3.0.0/lib/libgrass_gis.6.4.0RC5.so
-L/afs/isis.unc.edu/pkg/grass-6.4.0/.build/rs_aix53/
grass-6.4.0RC5/dist.powerpc-ibm-aix5.3.0.0/lib -L/usr/local/lib
-L/opt/freeware/lib -L/usr/lib -L/usr/X11R6/lib -L/usr/lib/threads -lc
-L/usr/lib -L/usr/l
ocal/lib
-L/afs/isis.unc.edu/pkg/grass-6.4.0/.build/rs_aix53/grass-6.4.0RC5/dist.powerpc-ibm-aix5.3.0.0/lib
OBJ.powerpc-ibm-aix5.3.0.0/adj_cellhd.o OBJ.p
owerpc-ibm-aix5.3.0.0/align_window.o OBJ.powerpc-ibm-aix5.3.0.0/alloc.o
OBJ.powerpc-ibm-aix5.3.0.0/alloc_cell.o
OBJ.powerpc-ibm-aix5.3.0.0/area.o OBJ.powerp
c-ibm-aix5.3.0.0/area_ellipse.o OBJ.powerpc-ibm-aix5.3.0.0/area_poly1.o
OBJ.powerpc-ibm-aix5.3.0.0/area_poly2.o
OBJ.powerpc-ibm-aix5.3.0.0/area_sphere.o OBJ
.powerpc-ibm-aix5.3.0.0/ascii_chk.o OBJ.powerpc-ibm-aix5.3.0.0/ask.o
OBJ.powerpc-ibm-aix5.3.0.0/ask_cell.o
OBJ.powerpc-ibm-aix5.3.0.0/ask_vctrs.o OBJ.powerp
c-ibm-aix5.3.0.0/asprintf.o OBJ.powerpc-ibm-aix5.3.0.0/auto_mask.o
OBJ.powerpc-ibm-aix5.3.0.0/basename.o
OBJ.powerpc-ibm-aix5.3.0.0/bres_line.o OBJ.powerpc-
ibm-aix5.3.0.0/cats.o OBJ.powerpc-ibm-aix5.3.0.0/cell_stats.o
OBJ.powerpc-ibm-aix5.3.0.0/cell_title.o
OBJ.powerpc-ibm-aix5.3.0.0/cellstats_eq.o OBJ.powerpc-
ibm-aix5.3.0.0/clear_scrn.o OBJ.powerpc-ibm-aix5.3.0.0/clicker.o
OBJ.powerpc-ibm-aix5.3.0.0/closecell.o
OBJ.powerpc-ibm-aix5.3.0.0/color_compat.o OBJ.powerp
c-ibm-aix5.3.0.0/color_free.o OBJ.powerpc-ibm-aix5.3.0.0/color_get.o
OBJ.powerpc-ibm-aix5.3.0.0/color_hist.o
OBJ.powerpc-ibm-aix5.3.0.0/color_init.o OBJ.pow
erpc-ibm-aix5.3.0.0/color_insrt.o
OBJ.powerpc-ibm-aix5.3.0.0/color_invrt.o
OBJ.powerpc-ibm-aix5.3.0.0/color_look.o
OBJ.powerpc-ibm-aix5.3.0.0/color_org.o OB
J.powerpc-ibm-aix5.3.0.0/color_rand.o
OBJ.powerpc-ibm-aix5.3.0.0/color_range.o
OBJ.powerpc-ibm-aix5.3.0.0/color_read.o
OBJ.powerpc-ibm-aix5.3.0.0/color_remo
ve.o OBJ.powerpc-ibm-aix5.3.0.0/color_rule.o
OBJ.powerpc-ibm-aix5.3.0.0/color_rule_get.o
OBJ.powerpc-ibm-aix5.3.0.0/color_rules.o OBJ.powerpc-ibm-aix5.3.0.0
/color_set.o OBJ.powerpc-ibm-aix5.3.0.0/color_shift.o
OBJ.powerpc-ibm-aix5.3.0.0/color_str.o
OBJ.powerpc-ibm-aix5.3.0.0/color_write.o OBJ.powerpc-ibm-aix5.3
.0.0/color_xform.o OBJ.powerpc-ibm-aix5.3.0.0/commas.o
OBJ.powerpc-ibm-aix5.3.0.0/copy.o OBJ.powerpc-ibm-aix5.3.0.0/copy_dir.o
py_file.o OBJ.powerpc-ibm-aix5.3.0.0/date.o
OBJ.powerpc-ibm-aix5.3.0.0/datum.o OBJ.powerpc-ibm-aix5.3.0.0/debug.o
OBJ.powerpc-ibm-aix5.3.0.0/dig_title.o OBJ
.powerpc-ibm-aix5.3.0.0/distance.o OBJ.powerpc-ibm-aix5.3.0.0/done_msg.o
OBJ.powerpc-ibm-aix5.3.0.0/endian.o OBJ.powerpc-ibm-aix5.3.0.0/env.o
OBJ.powerpc-ib
m-aix5.3.0.0/error.o OBJ.powerpc-ibm-aix5.3.0.0/file_name.o
OBJ.powerpc-ibm-aix5.3.0.0/find_cell.o
OBJ.powerpc-ibm-aix5.3.0.0/find_etc.o OBJ.powerpc-ibm-aix
5.3.0.0/find_file.o OBJ.powerpc-ibm-aix5.3.0.0/find_vect.o
OBJ.powerpc-ibm-aix5.3.0.0/flate.o OBJ.powerpc-ibm-aix5.3.0.0/fork.o
ormat.o OBJ.powerpc-ibm-aix5.3.0.0/fpreclass.o
OBJ.powerpc-ibm-aix5.3.0.0/gdal.o OBJ.powerpc-ibm-aix5.3.0.0/geodesic.o
OBJ.powerpc-ibm-aix5.3.0.0/geodist.o
OBJ.powerpc-ibm-aix5.3.0.0/get_cellhd.o
OBJ.powerpc-ibm-aix5.3.0.0/get_datum_name.o
OBJ.powerpc-ibm-aix5.3.0.0/get_ell_name.o OBJ.powerpc-ibm-aix5.3.0.0/get
_ellipse.o OBJ.powerpc-ibm-aix5.3.0.0/get_projinfo.o
OBJ.powerpc-ibm-aix5.3.0.0/get_projname.o
OBJ.powerpc-ibm-aix5.3.0.0/get_row.o OBJ.powerpc-ibm-aix5.3.0
.0/get_row_colr.o OBJ.powerpc-ibm-aix5.3.0.0/get_window.o
OBJ.powerpc-ibm-aix5.3.0.0/getl.o OBJ.powerpc-ibm-aix5.3.0.0/gets.o
OBJ.powerpc-ibm-aix5.3.0.0/gis
base.o OBJ.powerpc-ibm-aix5.3.0.0/gisdbase.o
OBJ.powerpc-ibm-aix5.3.0.0/gishelp.o
OBJ.powerpc-ibm-aix5.3.0.0/gisinit.o OBJ.powerpc-ibm-aix5.3.0.0/histo_eq.o
 OBJ.powerpc-ibm-aix5.3.0.0/histogram.o
OBJ.powerpc-ibm-aix5.3.0.0/history.o OBJ.powerpc-ibm-aix5.3.0.0/home.o
OBJ.powerpc-ibm-aix5.3.0.0/icon.o OBJ.powerpc
-ibm-aix5.3.0.0/index.o OBJ.powerpc-ibm-aix5.3.0.0/init_map.o
OBJ.powerpc-ibm-aix5.3.0.0/interp.o
OBJ.powerpc-ibm-aix5.3.0.0/intersect.o OBJ.powerpc-ibm-aix
5.3.0.0/intr_char.o OBJ.powerpc-ibm-aix5.3.0.0/is.o
OBJ.powerpc-ibm-aix5.3.0.0/key_value1.o
OBJ.powerpc-ibm-aix5.3.0.0/key_value2.o OBJ.powerpc-ibm-aix5.3.0
.0/key_value3.o OBJ.powerpc-ibm-aix5.3.0.0/key_value4.o
OBJ.powerpc-ibm-aix5.3.0.0/legal_name.o
OBJ.powerpc-ibm-aix5.3.0.0/line_dist.o OBJ.powerpc-ibm-aix5.
3.0.0/list.o OBJ.powerpc-ibm-aix5.3.0.0/ll_format.o
OBJ.powerpc-ibm-aix5.3.0.0/ll_scan.o OBJ.powerpc-ibm-aix5.3.0.0/locale.o
tion.o OBJ.powerpc-ibm-aix5.3.0.0/ls.o
OBJ.powerpc-ibm-aix5.3.0.0/mach_name.o
OBJ.powerpc-ibm-aix5.3.0.0/make_colr.o
OBJ.powerpc-ibm-aix5.3.0.0/make_loc.o O
BJ.powerpc-ibm-aix5.3.0.0/make_mapset.o
OBJ.powerpc-ibm-aix5.3.0.0/mapcase.o OBJ.powerpc-ibm-aix5.3.0.0/mapset.o
OBJ.powerpc-ibm-aix5.3.0.0/mapset_msc.o OBJ
.powerpc-ibm-aix5.3.0.0/mapset_nme.o
OBJ.powerpc-ibm-aix5.3.0.0/mask_info.o
OBJ.powerpc-ibm-aix5.3.0.0/maskfd.o OBJ.powerpc-ibm-aix5.3.0.0/myname.o
OBJ.powe
rpc-ibm-aix5.3.0.0/named_colr.o
OBJ.powerpc-ibm-aix5.3.0.0/nl_to_spaces.o
OBJ.powerpc-ibm-aix5.3.0.0/nme_in_mps.o
OBJ.powerpc-ibm-aix5.3.0.0/null_val.o OBJ.
powerpc-ibm-aix5.3.0.0/open.o OBJ.powerpc-ibm-aix5.3.0.0/open_misc.o
OBJ.powerpc-ibm-aix5.3.0.0/opencell.o
OBJ.powerpc-ibm-aix5.3.0.0/overwrite.o OBJ.powerp
c-ibm-aix5.3.0.0/parser.o OBJ.powerpc-ibm-aix5.3.0.0/paths.o
OBJ.powerpc-ibm-aix5.3.0.0/percent.o OBJ.powerpc-ibm-aix5.3.0.0/plot.o
.0/pole_in_poly.o OBJ.powerpc-ibm-aix5.3.0.0/popen.o
OBJ.powerpc-ibm-aix5.3.0.0/progrm_nme.o
OBJ.powerpc-ibm-aix5.3.0.0/proj1.o OBJ.powerpc-ibm-aix5.3.0.0/p
roj2.o OBJ.powerpc-ibm-aix5.3.0.0/proj3.o
OBJ.powerpc-ibm-aix5.3.0.0/put_cellhd.o
OBJ.powerpc-ibm-aix5.3.0.0/put_row.o OBJ.powerpc-ibm-aix5.3.0.0/put_title.
o OBJ.powerpc-ibm-aix5.3.0.0/put_window.o
OBJ.powerpc-ibm-aix5.3.0.0/putenv.o OBJ.powerpc-ibm-aix5.3.0.0/quant.o
OBJ.powerpc-ibm-aix5.3.0.0/quant_io.o OBJ.p
owerpc-ibm-aix5.3.0.0/quant_rw.o OBJ.powerpc-ibm-aix5.3.0.0/radii.o
OBJ.powerpc-ibm-aix5.3.0.0/range.o OBJ.powerpc-ibm-aix5.3.0.0/raster.o
OBJ.powerpc-ibm-a
ix5.3.0.0/raster_metadata.o OBJ.powerpc-ibm-aix5.3.0.0/rd_cellhd.o
OBJ.powerpc-ibm-aix5.3.0.0/reclass.o OBJ.powerpc-ibm-aix5.3.0.0/remove.o
OBJ.powerpc-ibm-
aix5.3.0.0/rename.o OBJ.powerpc-ibm-aix5.3.0.0/rhumbline.o
OBJ.powerpc-ibm-aix5.3.0.0/rotate.o OBJ.powerpc-ibm-aix5.3.0.0/sample.o
0/set_window.o OBJ.powerpc-ibm-aix5.3.0.0/short_way.o
OBJ.powerpc-ibm-aix5.3.0.0/sleep.o OBJ.powerpc-ibm-aix5.3.0.0/snprintf.o
OBJ.powerpc-ibm-aix5.3.0.0/sp
awn.o OBJ.powerpc-ibm-aix5.3.0.0/squeeze.o
OBJ.powerpc-ibm-aix5.3.0.0/store.o OBJ.powerpc-ibm-aix5.3.0.0/strings.o
OBJ.powerpc-ibm-aix5.3.0.0/system.o OBJ.p
owerpc-ibm-aix5.3.0.0/tempfile.o OBJ.powerpc-ibm-aix5.3.0.0/timestamp.o
OBJ.powerpc-ibm-aix5.3.0.0/token.o OBJ.powerpc-ibm-aix5.3.0.0/trim_dec.o
OBJ.powerpc
-ibm-aix5.3.0.0/unctrl.o OBJ.powerpc-ibm-aix5.3.0.0/unix_socks.o
OBJ.powerpc-ibm-aix5.3.0.0/user_config.o
OBJ.powerpc-ibm-aix5.3.0.0/verbose.o OBJ.powerpc-i
bm-aix5.3.0.0/view.o OBJ.powerpc-ibm-aix5.3.0.0/whoami.o
OBJ.powerpc-ibm-aix5.3.0.0/win32_pipes.o
OBJ.powerpc-ibm-aix5.3.0.0/wind_2_box.o OBJ.powerpc-ibm-ai
x5.3.0.0/wind_format.o OBJ.powerpc-ibm-aix5.3.0.0/wind_in.o
OBJ.powerpc-ibm-aix5.3.0.0/wind_limits.o
OBJ.powerpc-ibm-aix5.3.0.0/wind_overlap.o OBJ.powerpc-i
bm-aix5.3.0.0/wind_scan.o OBJ.powerpc-ibm-aix5.3.0.0/window_map.o
OBJ.powerpc-ibm-aix5.3.0.0/wr_cellhd.o
OBJ.powerpc-ibm-aix5.3.0.0/writ_zeros.o OBJ.powerpc
-ibm-aix5.3.0.0/yes.o OBJ.powerpc-ibm-aix5.3.0.0/zero.o
OBJ.powerpc-ibm-aix5.3.0.0/zero_cell.o OBJ.powerpc-ibm-aix5.3.0.0/zone.o
-lz   -lgrass_datetime  -lm
(cd
/afs/isis.unc.edu/pkg/grass-6.4.0/.build/rs_aix53/grass-6.4.0RC5/dist.powerpc-ibm-aix5.3.0.0/lib;
ln -f -s libgrass_gis.6.4.0RC5.so /afs/isis.unc.edu/pk
g/grass-6.4.0/.build/rs_aix53/grass-6.4.0RC5/dist.powerpc-ibm-aix5.3.0.0/lib/libgrass_gis.so)
noDotA="/afs/isis.unc.edu/pkg/grass-6.4.0/.build/rs_aix53/grass-6.4.0RC5/dist.powerpc-ibm-aix5.3.0.0/lib/libgrass_gis.6.4.0RC5.so"
ld: 0706-006 Cannot find or open library file: -l grass_datetime
        ld:open(): A file or directory in the path name does not exist.
make[3]: ***
[/afs/isis.unc.edu/pkg/grass-6.4.0/.build/rs_aix53/grass-6.4.0RC5/dist.powerpc-ibm-aix5.3.0.0/lib/libgrass_gis.6.4.0RC5.so]
Error 255
make[3]: Leaving directory
What's odd here is that it did build the grass_datetime library earlier,
so I'm not sure why it can't find it.
/afs/isis/pkg/grass-6.4.0/build/grass-6.4.0RC5/dist.powerpc-ibm-aix5.3.0.0/lib
ls -l libgrass_datetime*
-rwxr-xr-x    1 mwaldron employee      57923 Dec 11 11:03
libgrass_datetime.6.4.0RC5.so
lrwxr-xr-x    1 mwaldron employee         29 Dec 11 11:03
libgrass_datetime.so@ -> libgrass_datetime.6.4.0RC5.so
Glynn Clements wrote:
> Mike Waldron wrote:
>> I have successfully compiled GRASS 6.4.0RC5 on RedHat Enterprise Linux
>> 5. I am also trying to compile it on AIX 5.3 and having a great deal of
>> difficulty.
>> Has anyone successfully compiled it on AIX 5.3? If so, can you please
>> provide the configure options and any compiler-related environment
>> variables that you used?
> If you get configure errors, please post the relevant portion of
> config.log (everything from the "checking for ..." message
> corresponding to the failed test to the end of the file). Don't worry
> about error messages for tests which ultimately pass; those are quite
> normal.
> If configure succeeds but you get compilation errors, post the
> relevant portion of the output from "make" (from the "Entering
> directory ..." to the matching "Leaving directory ..." for a directory
> which fails). If you get errors building a library, anything which
> depends upon the library will fail, so only post the errors relating
> to building the library itself.
