[GRASS-user] Re: v.breach addon
Maciej Sieczka msieczka at sieczka.org
Mon Dec 14 12:17:46 EST 2009
Luís Ferreira pisze:
> I used v.breach with both SQLite and dbf, with ETRS89 metric negative
>  coordinates, from 20m to 2m resolution and worked fine.
> System: Ubuntu 9.10 Karmic Koala, 64 bits, GRASS 6.4SVN.
> But I remember to see some warnings like yours. Are these warnings
> critical? Visually, the interpolated DEMs with v.surf.rst are
> coherent.
I'll let you know next time I take a hobbyist look at v.breach. But I
really don't know when it will be.
Good luck.
Maciek
> On Mon, 2009-12-14 at 04:57 +0100, Maciej Sieczka wrote:
>> @Luís: I applied most your of patch. Thanks! Are you sure that's
>> all errors? I keep on getting warnings like:
>> WARNING: Unable to get point on line: cat = 1 offset = 2.831711
>> (line length = 0)
>> at v.segment calls in the script, and a crash at v.in.ascii.
Maciej Sieczka
http://www.sieczka.org
