[GRASS-user] Re: v.breach addon
M S mseibel at gmail.com
Mon Dec 14 15:52:07 EST 2009
Luis:
I noticed you mentioned you had run it with sqlite and dbf database
drivers.  Mine is mapped to sqlite currently.  I see some v.to.db
commands in the script, but do I understand correctly that you didnt
have issues using sqlite as backend?
Thanks,
Mark
2009/12/14 Luís Ferreira <lferreira75.1 at gmail.com>:
> I used v.breach with both SQLite and dbf, with ETRS89 metric negative
> coordinates, from 20m to 2m resolution and worked fine.
> System: Ubuntu 9.10 Karmic Koala, 64 bits, GRASS 6.4SVN.
> But I remember to see some warnings like yours. Are these warnings
> critical? Visually, the interpolated DEMs with v.surf.rst are coherent.
> Luís
> On Mon, 2009-12-14 at 04:57 +0100, Maciej Sieczka wrote:
>> @Luís: I applied most your of patch. Thanks! Are you sure that's all
>> errors? I keep on getting warnings like:
>> WARNING: Unable to get point on line: cat = 1 offset = 2.831711 (line
>>           length = 0)
>> at v.segment calls in the script, and a crash at v.in.ascii.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
