[GRASS-user] NVIZ on wxpython 6.4
Gilbert Ferrara
gilbertferrara1974 at gmail.com
Tue Dec 15 13:20:56 EST 2009
Greetings you all
I'm new at this mailing list and I have a question related with NVIZ module.
I saw in previous messages that NVIZ is available at WinGRASS using TclTK.
But at LINUX it also requires tcltk, right?
Ok I used the command: nviz elevation vect=roadsmajor points=firestations
and I get NVIZ window totally jammed. And when I unselected "surface" I got
this error window:
Bad window path name ".help_shell"
bad window path name ".help_shell"
while executing
"winfo reqwidth $_top"
(procedure "DynamicHelp::_show_help" line 22)
invoked from within
"DynamicHelp::_show_help .middle.panelarea.panels.main.midt.b2 317 323"
("after" script)
Question: Does any one LINUX User, has the same problem? Or knows how to fix
this?
Thanks
Gilbert
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20091215/406f3d80/attachment-0001.html
