[GRASS-user] Re: CYGWIN
Luigi Ponti lponti at infinito.it
Tue Dec 15 13:37:28 EST 2009
On 14/12/2009 18:17, Glynn Clements wrote:
> Luigi Ponti wrote:
>>>> But when I do /db.test test1/ errors arise:
>>> My guess is that this is a problem with Cygwin and Windows 7.
>> I have eventually reverted back to GRASS 6.3.0 for now, after fixing
>> some missing dll's. I am not sure what is wrong with 6.4 vs 6.3 but I
>> need a functional GRASS/Cygwin version to run some bash scripts while I
>> port them to Phython.
> I wouldn't consider the supplied db.test test case failing to equate
> to "non-functional"; it's the test case which is wrong, not db.select.
You are right: I used the wrong words -- thanks for the explanation. I
will keep trying to get 6.4.0-RC5 compiled on Cygwin/Windows 7. Thanks
again for sharing your configure options.
> If you care about the exact format of floating-point values output
> from db.select, note that future versions will behave like 6.4.0-RC5,
> not like 6.3.x.
Good to know, thanks.
>> Also, is it even possible to do Python scripting in the native Windows
>> GRASS 6.4.x?
> Yes.
>> For example, I noticed that some of the GRASS scripts that
>> have been translated to Python require a grass.py package, which I don't
>> see in my osgeo4w installation.
> There is no grass.py. It existed for a brief time, but the "grass"
> module was replaced with a "grass" package containing multiple
> modules, then later split into two subpackages, "script" and "lib".
The package is described in the programming manual -- I should have
explored better:
http://download.osgeo.org/grass/grass6_progman/pythonlib.html
The progman page above says that the code is in lib/python/ while in my
osgeo4w GRASS 6.4.0svn r36506
http://trac.osgeo.org/osgeo4w/wiki/pkg-grass
the code seems to reside into etc/python.
> The change was made to accomodate the SWIG bindings for the GRASS
> libraries in the "grass.lib" package, so the scripting functions were
> moved from "grass" to "grass.script".
Would the lib subpackage you mentioned be any useful in developing GRASS
scripts? (I could not find it in my osgeo4w installation.)
Thanks and regards,
Luigi
> Some early scripts use "import grass", but for current versions
> (including 6.4.0-RC5), you need e.g. "import grass.script as grass".
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20091215/0fa7ceee/attachment.html
