[GRASS-user] GRASS Scripting questions
Thu Dec 17 16:50:49 EST 2009
António Rocha wrote:
> Greetings Achim
> You are absolutely right. I made a mistake copying the expression.
> Here it goes:
> #itinialization of counter1
> r.mapcalc $GIS_OPT_COUNTER1= "float (0)"
> The cycle:
> IFS=,
> for opt in $GIS_OPT_INPUT; do
>    r.mapcalc $GIS_OPT_COUNTER= "$opt+$GIS_OPT_COUNTER"
> done
Don't use the same map as both input and output. Instead:
	tmp=tmp.myscript.$$
		r.mapcalc "$tmp = $opt + $GIS_OPT_COUNTER"
		g.rename --o rast=$tmp,$GIS_OPT_COUNTER
	done
Although for this specific task (adding a list of maps), use
"r.series ... method=sum".
