[GRASS-user] r.proj: fixing a failure
Rich Shepard rshepard at appl-ecosys.com
Tue Dec 22 13:46:01 EST 2009
On Tue, 22 Dec 2009, Daniel Victoria wrote:
> Could it be that the vector created by v.in.region is messed up, or
> it's covering a larger area that you are not interested in?
Daniel,
   Anything's possible at this point. I've apparently trashed the target
location's projection; trying to set it to an existing vector map results in
negative values and an inability to display any of the reprojected vector
maps. I suppose I need to start over. Sigh. Can't bill the client for this
time.
> Last time I used r.proj here is how I did it:
> 1) Go to source location and set the region to match the area I want to project
   There are differences between the raster DEM location's region and that of
all the vector maps. The former is the northwest portion of the latter. I
would have thought that the smaller region would easily be accommodated by
the larger one, with (perhaps) the northern and western bounds adjusted to
match.
   I'll work on this part first.
Thanks,
Rich
