[GRASS-user] Cannot Create UTM Location: -6.5svn
Wed Dec 30 01:10:13 EST 2009
Hamish wrote:
> >   I just used a text editor on PROJ_INFO after
> > accepting the default '30'.
> In that case you should double check that if(?) the PROJ_INFO
> file has a +lon_0 set, it is set appropriately and not still
> using the central longitude from Zone 30...
Also: the DEFAULT_WIND and WIND files contain a zone field.
