[GRASS-user] wxpython: vdigit crash
Craig Leat craig.leat at gmail.com
Tue Feb 3 08:05:39 EST 2009
Hi Martin
Martin Landa:
> right, here it works;-) Try to enable also vdigit debuging
> export GRASS_WX_DEBUG=3
> g.gisenv set=DEBUG=3
> last 50 lines of debug output should be enough...
50 lines of debug output attached.
This snippet looks strange (the last two values are very LARGE):
D3/3:   Box(N,S,E,W,T,B): -2.891490e+01, -3.014472e+01, 3.091949e+01,
2.948216e+01, 1.797693e+308, -1.797693e+308
Regards
Craig
D3/3: dig_spidx_add_node(): node = 23, x,y,z = 30.536160, -29.567100, 0.000000
D3/3: dig_spidx_add_line(): line = 1
D3/3: dig_spidx_add_line(): line = 2
D3/3: dig_spidx_add_line(): line = 3
D3/3: dig_spidx_add_line(): line = 4
D3/3: dig_spidx_add_line(): line = 5
D3/3: dig_spidx_add_line(): line = 6
D3/3: dig_spidx_add_line(): line = 7
D3/3: dig_spidx_add_line(): line = 8
D3/3: dig_spidx_add_line(): line = 9
D3/3: dig_spidx_add_line(): line = 10
D3/3: dig_spidx_add_line(): line = 11
D3/3: dig_spidx_add_line(): line = 12
D3/3: dig_spidx_add_line(): line = 13
D3/3: dig_spidx_add_line(): line = 14
D3/3: dig_spidx_add_line(): line = 15
D3/3: dig_spidx_add_line(): line = 16
D3/3: dig_spidx_add_line(): line = 17
D3/3: dig_spidx_add_line(): line = 18
D3/3: dig_spidx_add_line(): line = 19
D3/3: dig_spidx_add_line(): line = 20
D3/3: dig_spidx_add_line(): line = 21
D3/3: dig_spidx_add_line(): line = 22
D3/3: dig_spidx_add_line(): line = 23
D3/3: dig_spidx_add_line(): line = 24
D3/3: dig_spidx_add_line(): line = 25
D3/3: dig_spidx_add_line(): line = 26
D3/3: dig_spidx_add_line(): line = 27
D3/3: dig_spidx_add_line(): line = 28
D3/3: dig_spidx_add_line(): line = 29
D3/3: dig_spidx_add_area(): area = 1
D3/3: dig_spidx_add_area(): area = 2
D3/3: dig_spidx_add_area(): area = 3
D3/3: dig_spidx_add_area(): area = 4
D3/3: dig_spidx_add_area(): area = 5
D3/3: dig_spidx_add_area(): area = 6
D3/3: dig_spidx_add_area(): area = 7
D3/3: dig_spidx_add_isle(): isle = 1
D3/3: Spatial index was built
D1/3: Vect_get_dblink(): link = 0
D3/3: Vect_subst_var(): in = $GISDBASE/$LOCATION_NAME/$MAPSET/sqlite.db, map = LMs, mapset = craig
D3/3:   -> /home/craig/GIS/grassdata/uMDM/craig/sqlite.db
D2/3: wxDigit.InitCats(): nfields=2
D3/3: wxDigit.InitCats(): layer=1, cat=8
D3/3: Vect_select_lines_by_box()
D3/3:   Box(N,S,E,W,T,B): -2.891490e+01, -3.014472e+01, 3.091949e+01, 2.948216e+01, 1.797693e+308, -1.797693e+308
D3/3: dig_select_lines()
D3/3:   29 lines selected (all types)
D3/3:   29 lines of requested type
D3/3: wxDriver.DrawMap(): region: w=29.482160, e=30.919490, s=-30.144720, n=-28.914900
GRASS 6.5.svn (uMDM):~ >
