[GRASS-user] Sampling multispectral data
Ned Horning horning at amnh.org
Wed Feb 4 05:29:22 EST 2009
Greetings,
I am looking into the possibility of using GRASS with the R Random
Forest algorithm to create a land cover classification. I read the
Furlanello, Neteler et al. paper (very nice) and some others but I need
some help with the details. My problem is somewhat different from the
Furlanello, Neteler et al. paper since my sample data are coming from a
multispectral image instead of a database. I still have to get up to
speed with R and the Random Forest algorithm but I have an initial GRASS
question.
What I want to do is select a number of samples representing each land
cover type from a multispectral image. These data would then be input
into the Random Forest model to create the classification rules. For
example, I'm thinking that I will need to create vector polygons for
each land cover type I'm interested in. To keep it simple for this
explanation I'll use forest and non-forest. I'll digitize a few polygons
that represent forest and a few more that represent non-forest. Next, I
will need to sample the multispectral image data by selecting 500
randomly selected pixels that fall under the forest polygons and
another 500 pixels from under the non-forest polygons. How can I do this
in GRASS? I suppose I can run v.random to create a vector point layer of
random points within each land cover class (specify zmin and zmax as the
same value?) but then how would I use the point layer to get the
spectral information from an image group? I will also need to format the
sample data so that R can read it.
If anyone has advice or resources they can point me to regarding the use
of Random Forests or CART in GRASS please let me know
All the best,
Ned
