[GRASS-user] problem setting region in 6.4 rc3
Nick Cahill ndcahill at wisc.edu
Wed Feb 4 09:41:27 EST 2009
That was the problem - it was using TclTk 8.4 instead of 8.5. On
deleting 8.4, it works perfectly. Thank you!
Nick Cahill
On Feb 3, 2009, at 9:17 AM, William Kyngesburye wrote:
> On Feb 3, 2009, at 8:40 AM, Nick Cahill wrote:
>> Hello,
>> Further on this. I tried creating a new location and mapset to see
>> if there were differences in the projection parameters or if
>> something was screwy. On startup, it gives an error I hadn't
>> noticed before,
>> Warning: TclTk Aqua 8.4 unsupported
> Do you have TclTk 8.5 Aqua installed?  Is it the ActiveTcl binary,
> another binary, or did you build from source?
> That's just a warning, I don't disable TclTk 8.4 Aqua in GRASS (I'm
> not sure if I can).  So it will still try to use it, which does not
> appear to work for defining a location.
> So, the location setup was done in the GUI location setup tool?
> (which would have been running TclTk 8.4 Aqua)
>> region for current mapset <projection field missing>
>> run "g.region"
> Did you try running g.region right in the Terminal?  Save the
> current region, which seems to be OK:
>  g.region -s
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> All generalizations are dangerous, even this one.
