[GRASS-user] Importing ArcASCII raster and associated dbf table?
Hamish hamish_b at yahoo.com
Thu Feb 5 18:37:25 EST 2009
Jarl Devereux wrote:
> I'm new to grass and I'm trying to import an ArcASCII raster file with
> an associated dbf table into a cygwin grass 6.2.
> I have been using r.in.gdal to import the raster without issue
(r.in.arc might work too)
> however handling the attribute data is still a mystery to me.
> Can I connect a raster to a dbf table or add the attributes
> as layers?
what is the form of the fields in the database?
If simply category:label you can use the rules= option of the r.category
module in GRASS 6.3+ to attach them. For GRASS 6.2 you would have to
create the cats/ file by hand. (it's just a text file)
see http://grass.osgeo.org/grass64/manuals/html64_user/r.category.html
There is the possibility that you could pipe the dbf into r.category
with the "dbview" utility.
> The db.* commands seemed to be only vector based
right,
> so I converted the raster to an area vector using the raster values
> as the cat. I am not sure of the steps to copy or attach the arc dbf
> table.
v.db.connect?
> my cat values are not consecutive
that's ok
> and the .dbf table that accompanied the data doesn't have a "cat" column
> it has a consecutive "value" column instead.
so is the Arc map categorical or floating point real numbers? what does
it represent?
is the DBF file like 0.0-500m: Lowlands   500.0-1000.0m Midlands
1000.0-3000.0m Highlands or......?
> How do I go about adding this table to the vector so it correctly
> matches up "value" and "cat"?
need more info.
Hamish
