[GRASS-user] Re: Calculating standard error of many maps?
John C. Tull jctull at gmail.com
Mon Feb 9 11:19:27 EST 2009
On Feb 9, 2009, at 8:15 AM, Moritz Lennert wrote:
> On 09/02/09 16:59, Rainer M Krug wrote:
>> Just one clarification: I would like to calculate these descriptive
>> stats for each cell, to obtain "variability maps".
>> Rainer
>> On Mon, Feb 9, 2009 at 5:57 PM, Rainer M Krug <r.m.krug at gmail.com>
>> wrote:
>>> Hi
>>> I have 25000 maps, generated by simulation predictions, and I would
>>> like to calculate some descriptive stats, like mean, standard
>>> deviation, median, quartiles.
>>> Is there an easy way of doing this in GRASS?
> r.series ?
> You will probably have to use xargs to collate that many map names...
Or you can use g.mlist if the names have a common prefix, suffix, etc.
This assumes you want a single map that displays the result of all the
input maps.
E.g.
r.series input="`g.mlist rast pattern='prefix_*' sep=,`"
output=prefix_stddev method=stddev
John
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20090209/d4d5acf7/attachment.html
