[GRASS-user] Creating turbidity raster file
buraq zakkey at gmail.com
Tue Feb 10 03:50:05 EST 2009
Dylan Beaudette wrote:
> On Monday 09 February 2009, Hamish wrote:
>> buraq wrote:
>> > I have formatted csv files for every month which is like
>> > latitude;longitude;turbidityValue. So I want to create
>> > raster files from these csvs for using in r.sun.
>> v.in.ascii -> convert .csv to a vector points file
>> g.region  # set up raster grid
>> v.surf.rast -> interpolate vector points to raster surface
> Minor correction:
> v.surf.rast ---> v.surf.rst
>> I have worried about r.sun's Linke Turbidity factor values in areas with
>> big changes in elevation. Is turbidity value heavily dependent on
>> altitude?
> It should, as it is based on a measure of optical thickness (air mass):
> -------- Extracted from a document ------
> m = \frac{1}{sin(\alpha) + 0.15(\alpha + 3.885)^{-1.253}} e^{-0.0001184
> \times
> A}
> \noindent
> where $\alpha$ is the solar elevation angle at (12:00 pm local time) on
> each
> day of the year, and $A$ is the weather station elevation in meters above
> mean sea level (MSL).
> This stuff is also on pages 40-41 of this document:
> http://169.237.35.250/~dylan/d_e_beaudette-ms_thesis.pdf
> Cheers,
> Dylan
>> Hamish
> Dylan Beaudette
> Soil Resource Laboratory
> http://casoilresource.lawr.ucdavis.edu/
> University of California at Davis
> 530.754.7341
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
I took the turbidity values from soda-is.com. I entered no altitude value
for the latitude and longitude.
View this message in context: http://n2.nabble.com/Creating-turbidity-raster-file-tp2297732p2301484.html
Sent from the Grass - Users mailing list archive at Nabble.com.
