[GRASS-user] g.findfile
Vincent Bain bain at toraval.fr
Tue Feb 10 08:28:07 EST 2009
Using grass6.4.0svn (revision 35838), the result of g.findfile appears
not to run properly for raster query :
create a raster map test,
run g.findfile element=raster file=test.
Looks like the file does not exist :
name=
mapset=
fullname=
file=
(Tested successfully with a vector map)
What am I doing wrong ? I remember the command worked in previous
versions.
Thanks,
Vincent.
