[GRASS-user] g.findfile
Vincent Bain bain at toraval.fr
Tue Feb 10 08:43:21 EST 2009
Thank you Martin !
(for my info, is it a recent change or was the previous keyword really
'raster' ?)
Vincent
Le mardi 10 février 2009 à 14:39 +0100, Martin Landa a écrit :
> Hi,
> 2009/2/10 Vincent Bain <bain at toraval.fr>:
> > Using grass6.4.0svn (revision 35838), the result of g.findfile appears
> > not to run properly for raster query :
> > create a raster map test,
> > run g.findfile element=raster file=test.
> > Looks like the file does not exist :
> > name=
> > mapset=
> > fullname=
> > file=
> > (Tested successfully with a vector map)
> > What am I doing wrong ? I remember the command worked in previous
> > versions.
> use element=cell to find raster map
> Martin
