[GRASS-user] updating vector map using another vector map as criteria
Christopher Mire cnm3332 at gmail.com
Tue Feb 10 11:41:12 EST 2009
Is there a way I can update the attributes of one vector map, given another
vector map(vm)?
The selection vector map would be subset of original vm.  As an example,
using output
from v.net.path to update a column in original vm, say just updating some
arbitrary integer
field to signify that there was a match between original and other vm.
Thanks.
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20090211/dec23272/attachment.html
