[GRASS-dev] Re: [GRASS-user] Re: Calculating standard error of many maps?
Markus Neteler neteler at osgeo.org
Wed Feb 11 12:11:43 EST 2009
On Wed, Feb 11, 2009 at 11:08 AM, Glynn Clements
<glynn at gclements.plus.com> wrote:
> Regarding command-line limits: is it worth extending G_parser() to
> allow arguments to be read from a file? E.g. "r.series @args.txt".
> It was quite common for this feature to be added to DOS ports of Unix
> programs, as DOS had a much lower limit than Unix on the maximum
> length of a command line.
Just to understand - does this allow to exceed the command limits?
Then it would be pretty helpful (as text files are easy to generate).
Markus
