[GRASS-user] Thiessen Polygons
    Glynn Clements
    glynn at gclements.plus.com
    Sat Feb 14 05:54:55 EST 2009
Jan Hartmann wrote:
> With that in mind, if the algorithm you propose would be indeed an
> approximation to weighted Voronoi polygons, *and* it wouldn't be all to
> hard to implement (I have no idea about that), would it make sense to
> propose this as a new RFC for GRASS?
Oops; I spoke too soon.
In retrospect, this won't work. r.grow.distance relies upon the fact
that once a cell falls out of consideration, it stays out. It will
only consider cells which either are from the current row, or were
used on the previous row.
With distance scaling, this doesn't hold. A cell could be temporarily
overriden by much nearer cells with increased scale factors (lower
weights), then regain its influence once the distance increases.
IOW, this isn't something which can implemented given the algorithm
used by r.grow.distance. Any algorithm which implemented distance
scaling would inevitably have worst-case memory usage proportional to
the number of non-null input cells, as you can never "forget" a cell
whose scale factor is lower than those currently being considered, as
it will eventually regain its influence.
