[GRASS-user] Thiessen Polygons
Sun Feb 15 17:42:55 EST 2009
Jan Hartmann wrote:
> >> With that in mind, if the algorithm you propose would be indeed an
> >> approximation to weighted Voronoi polygons, *and* it wouldn't be all to
> >> hard to implement (I have no idea about that), would it make sense to
> >> propose this as a new RFC for GRASS?
> > Oops; I spoke too soon.
> > In retrospect, this won't work. r.grow.distance relies upon the fact
> > that once a cell falls out of consideration, it stays out. It will
> > only consider cells which either are from the current row, or were
> > used on the previous row.
> > With distance scaling, this doesn't hold. A cell could be temporarily
> > overriden by much nearer cells with increased scale factors (lower
> > weights), then regain its influence once the distance increases.
> > IOW, this isn't something which can implemented given the algorithm
> > used by r.grow.distance. Any algorithm which implemented distance
> > scaling would inevitably have worst-case memory usage proportional to
> > the number of non-null input cells, as you can never "forget" a cell
> > whose scale factor is lower than those currently being considered, as
> > it will eventually regain its influence.
> Do you mean that implementing a raster version of weighted Voronoi
> methods would be very inefficient, compared to vector methods, or that
> it would be very difficult?
I mean only that it cannot be done using the approach which
r.grow.distance uses, using memory proportional to the number of
columns (it uses a number of row buffers, i.e. one-dimensional arrays,
with one element per column).
[In any case, weighted distances won't produce polygons; at least, not
for Euclidean distances. The boundary will only be a straight line if
the weights are equal.]
However, that doesn't meant that other algorithms wouldn't be
feasible, particularly if you're only interested in typical behaviour
rather than worst-case behaviour.
Also, it may be possible to use the r.grow.distance approach with
something other than scaling. An offset would work, optionally
combined with a monotonic function of the distance (provided that it's
the same for every point).
