[GRASS-user] create raster from line vector
G. Allegri giohappy at gmail.com
Mon Feb 16 10:00:23 EST 2009
??? even the new one that I've uploaded?
2009/2/16 Nikos Alexandris <nikos.alexandris at felis.uni-freiburg.de>:
> On Mon, 2009-02-16 at 15:52 +0100, Nikos Alexandris wrote:
>> On Mon, 2009-02-16 at 15:40 +0100, G. Allegri wrote:
>> > I share my vector, if someone wants to reproduce this problem:
>> > http://www.geospatial.it/allegri/bordi.tar.gz
>> > EPSG:32632
>> Giovanni,
>> the shapefile's attribute table looks messed up. I just opened it with
>> QGIS and the column names are senseless characters. In addition, all
>> rows are filled with NULL.
>> I don't know it's just a "codepage" sort of problem or the reason for
>> your empty raster.
>> I will try with GRASS now. If I'll find something useful I'll post back.
> Sorry, I can't even read it with ogrinfo.
> ogrinfo /home/nik/Desktop/in/bordi.shp -al | head -100
> ERROR 3: fread(65004) failed on DBF file.
> INFO: Open of `/home/nik/Desktop/in/bordi.shp'
>      using driver `ESRI Shapefile' successful.
> Layer name: bordi
> Geometry: Line String
> Feature Count: 9
> Extent: (1009114.847644, 4446909.136474) - (1312106.717266,
> 4668313.355348)
> Layer SRS WKT:
> PROJCS["WGS_1984_UTM_Zone_32N",
>    GEOGCS["GCS_WGS_1984",
>        DATUM["WGS_1984",
>            SPHEROID["WGS_1984",6378137,298.257223563]],
>        PRIMEM["Greenwich",0],
>        UNIT["Degree",0.017453292519943295]],
>    PROJECTION["Transverse_Mercator"],
>    PARAMETER["latitude_of_origin",0],
>    PARAMETER["central_meridian",9],
>    PARAMETER["scale_factor",0.9996],
>    PARAMETER["false_easting",500000],
>    PARAMETER["false_northing",0],
>    UNIT["Meter",1]]
> ��N���nL at Q: String (17.0)
> L$D=�u����: String (207.0)
> �=? ��   �: String (191.0)
>  ��GMI�FYYY: String (78.0)
> '6:�+JX�fW`: String (235.0)
> g ��ʚ *;  : String (243.0)
>  _"*gD88Z��: String (109.0)
> 2U]「��@QU�: String (119.0)
> �'@TN�]����: String (223.0)
> �魗n�676t: String (117.0)
> +&<J W v���: String (136.0)
>  ���� \��  : String (212.0)
> o����7ʤ��: String (247.0)
> <�_\     ��: String (126.0)
> ˆøßøŒÿÛù¯L: S├⎼␋┼± (207.0)
> ;4OÓÓÐà 4´Þ: S├⎼␋┼± (32.0)
> B8¬┘┴šì¶%þ¿: S├⎼␋┼± (33.0)
> dž¸ ˜øæ%¬?│: S├⎼␋┼± (200.0)
> # it continues like that :-(
