[GRASS-user] Problemas con winGRASS 6.4.0RC3 del instalador OSGeo4W
Jarek Jasiewicz jarekj at amu.edu.pl
Mon Feb 16 12:05:06 EST 2009
g.region says:
EROR:Invalid ellipsoid '�' in file PROJ_INFO in <PERMANENT>
I removed PROJ_INFO and now grass can be used in gui (gis.m) mode
thanks for tip
Jarek
Markus Neteler pisze:
> On Sun, Feb 15, 2009 at 8:41 PM, Jarek Jasiewicz <jarekj at amu.edu.pl> wrote:
>> I confirm that error on old latlong location (created over 1 years ago, I
>> didn't use it since that time)
>> due to this error gis.m cannot start, but grass still working in the text
>> mode Addational masage in text console are:
>> Error in startup script: can't read "monitor_zooms(1,1,n)": no such variable
>>   while executing
> This is typically a GDAL problem.
> What does
>   g.region -p
> say? Please test this since you can use GRASS in text mode.
> Markus
