[GRASS-user] Problemas con winGRASS 6.4.0RC3 del instalador OSGeo4W
Jarek Jasiewicz jarekj at amu.edu.pl
Mon Feb 16 15:49:47 EST 2009
Markus Neteler pisze:
> On Mon, Feb 16, 2009 at 6:05 PM, Jarek Jasiewicz <jarekj at amu.edu.pl> wrote:
>> g.region says:
>> EROR:Invalid ellipsoid '� ' in file PROJ_INFO in <PERMANENT>
> How was the PROJ_INFO file generated?
> Which projection?
Sorry I don' rememer it was over one year ago.
projection lato long based on WGS84 elipsoid
>> I removed PROJ_INFO and now grass can be used in gui (gis.m) mode
>> thanks for tip
> It's no good to remove the file since you lose the spatial
> reference. Better to actually correct it...
> Markus
