[GRASS-user] Problem running r.terraflow
Margherita Di Leo diregola at gmail.com
Wed Feb 18 10:11:33 EST 2009
Hi all,
i have a problem using Grass 6.5 with a raster elevation map running the
command 'r.terraflow'.
I need to obtain the flow accumulation with MFD.
The error is the following:
'cell file dem resolution differs from current region'.
I ran the command 'g.region -ap rast=dem' and this is the result:
projection: 1 (UTM)
zone:       33
datum:      wgs84
ellipsoid:  wgs84
north:      6651087.53951495
south:      6541497.53951495
west:       500200.31922317
east:       649510.31922317
nsres:      10
ewres:      10
rows:       10959
cols:       14931
cells:      163628829
with 'r.info' the result is:
 Type of Map:  raster               Number of Categories: 255             |
 |   Data Type:
FCELL                                                      |
 |   Rows:
10959                                                      |
 |   Columns:
14931                                                      |
 |   Total Cells:
163628829                                                  |
 |        Projection: UTM (zone
33)                                           |
 |            N: 6651087.53951495    S: 6541497.53951495   Res:
10         |
 |            E: 649510.31922317    W: 500200.31922317   Res:
10           |
 |   Range of data:    min = 3.000000  max =
402.930878                       |
 |   Data
Description:                                                        |
 |    generated by
r.in.gdal                                                  |
Please can you help me? Any idea about what's wrong?
Sorry if my question is trivial.
Regards
Ing. Margherita Di Leo
Ph.D. Student
Methods and Technologies for Environmental Monitoring
Department of Environmental Engineering and Physics (DIFA)
University of Basilicata
Campus Macchia Romana
85100 - Potenza
Italy
Office: +39-0971205363
Fax: +39-0971205160
E-mail: dileomargherita at gmail.com
Skype: dileomargherita
URL: http://www.difa.unibas.it/A_Manager_PP.do?azione=visualizzaHomePage&id=106
