[GRASS-user] library problem with i.landsat.toar
Christine Sandmeier christine.sandmeier at gmx.de
Wed Feb 18 17:46:37 EST 2009
Hi list,
I wanted to install the i.landsat.toar - addon, following the instruction in the README-file (make MODULE_TOPDIR=$HOME/grass64/),
I also made "./configure" before and also "make lib", which says "Nothing to do for target »lib«"!
The procedure works fine for other addons (e.g. i.landsat.dehaze, v.what.rast.buffer and others),
but when I try to start the i.landsat.toar addon, it says "Incompatible library version for module".
I recompiled grass, but this didn't help.
I'm using grass6.4 on Ubuntu 8.10.
Thanks for any help,
Christine
Psssst! Schon vom neuen GMX MultiMessenger gehört? Der kann`s mit allen: http://www.gmx.net/de/go/multimessenger01
