[GRASS-user] improve v.rast.stats speed?
Markus Metz markus.metz.giswork at googlemail.com
Thu Feb 19 07:44:31 EST 2009
G. Allegri wrote:
> Hello list.
> Yesterday I needed to use v.rast.stats on a 1793 areas covering a
> 4415x6632 raster (with resolution 50m/pixel). I've used it without
> extended statistics but the processing time was, with an euphemism,
> very very long. After 5 hours it wasn't finished yet. As I needed it
> for today morning I've decided to reproduce it with ArcGIS: 40
> seconds. I've tried to investigate what was going wrong, the
> bottleneck, but at the end I suppose that it's a problem of the script
> itself (the looping chain of r.mapcalc and r.univar, the creation and
> deletion of the MASK in each loop).
> Is there any way to improve the performance of v.rast.stats? Should we
> rewrite it in C and avoid the use of MASKs?
I have two ideas.
1) Use r.reclass instead of r.mapcalc to create new masks. That should
speed up at least the MASK creation and deletion
2) Avoid the loop and MASK creation altogether. Run r.univar
map=tmpname,raster. Process the output of r.univar, separate stats for
the different vector areas and convert to sql statements. Proceed as
before. r.univar would be called only once. I'm not sure if this is
possible. I also don't know if the speed gain by avoiding the loop is
annihilated by r.univar having to process two rasters as input.
cc-ing to the dev list
Regards,
Markus M
