FW: FW: [GRASS-user] unable to install Grass
Jimmy Maro jimmy.maro at nari.org.pg
Fri Feb 20 21:02:15 EST 2009
I managed to get the mapset error sorted after reinstalling the program.
It still wont start its giving following error;
Python.exe - Unable to locate Component
This application has failed to start because ipp-5.3.dll was not found.
Reinstalling the application may fix this problem
Jimmy
-----Original Message-----
From: Jachym Cepicky [mailto:jachym.cepicky at gmail.com]
Sent: Friday, February 20, 2009 8:12 PM
To: Jimmy Maro; grass-user
Subject: RE: FW: FW: [GRASS-user] unable to install Grass
Jimmy Maro píše v Pá 20. 02. 2009 v 19:03 +1000:
> Hi Jachym,
> How do I check this out?
> Ta, Jim
if you start osgeo command line, and there are programs like ogr2ogr,
gdalinfo, ogrinfo available, if gdalinfo --formats and ogrinfo --formats
do give you GRASS Raster/Vector (among others) and if they are checked
in the packages-selection screen of the installator[1] (look in Libs)
jachym
[1] http://les-ejk.cz/skoleni/grass/about/_images/osgeo4win06.png
> Sent: Friday, February 20, 2009 6:57 PM
> To: Jimmy Maro
> Cc: grass-user at lists.osgeo.org
> Subject: Re: FW: FW: [GRASS-user] unable to install Grass
> Hi,
> I had similar problem on Windows.
> Is proj and gdal and gdal-grass libraries correctly installed?
> jachym
> Jimmy Maro píše v Pá 20. 02. 2009 v 09:37 +1000:
> > Hi all,
> > I can't startup Grass its giving me the following error msg:
> > Pls help
> > Ta,
> > Jimmy
> > grass-user mailing list
> > http://lists.osgeo.org/mailman/listinfo/grass-user
> Jachym Cepicky
> e-mail: jachym.cepicky gmail com
> URL: http://les-ejk.cz
> GPG: http://les-ejk.cz/pgp/JachymCepicky.pgp
Jachym Cepicky
No virus found in this incoming message.
Checked by AVG.
Version: 7.5.552 / Virus Database: 270.10.25/1957 - Release Date: 2/17/2009
7:07 AM
