[GRASS-user] GRASS 7 and SQLITE o POSTGRES
Gabriele N. gis.gn at libero.it
Sat Feb 21 08:25:17 EST 2009
Hi Moritz.
I have read here http://grass.osgeo.org/wiki/GRASS_7_ideas_collection
"Database
establish SQLite as default DBMI driver (DBF is too limited). done May 2008.
That's because I thought that SQLite support in GRASS 7 concerns the
attribute management and the geometries.
I use qgis and GRASS plugin already but I would like on NAS server create a
DB sqlite or postgres (not dbf).
Thanks
Gabriele
Moritz Lennert wrote:
> On 21/02/09 12:44, Gabriele N. wrote:
>> Hi Benjamin, thanks for the reply.
>> I read something about spatial lite.
>> I work mainly with GRASS and thought to use it with SQLite because GRASS
>> 7
>> should be able to work directly on the SQLite for the geometries and the
>> attributes (in short, without v.exeternal).
>> I think, but I do not know if it is correct, that implementing a DB in
>> SQLite might be possible to access data with GRASS 7, QGIS, gvSIG, etc...
>> (my colleagues still do not use GRASS) .... but maybe it's only my  hope
> The SQLite support in GRASS concerns the attribute management, not
> geometries. To access geometries in a SpatiaLite, you have to go through
> v.external.
> One of the main reasons is that GRASS vector format is topological and
> SpatiaLite isn't. Most vector modules expect topological structure to
> work.
>> With postgres/postgis I should always connect with v.external and I could
>> not do spatial analysis using the tools of GRASS ... right?
> Right, but it is the same for SpatiaLite.
> Note that QGIS can access GRASS data directly (not sure about gvSIG) so
> you can actually have your geometries in GRASS format and still work
> with QGIS.
> Moritz
>> Thank you very much
>> Gabriele
>> Benjamin Ducke wrote:
>>> Hi Gabriele,
>>> A spatial database extension allows you to store
>>> geographic features as part of the database itself.
>>> There are many advantages to this, especially if you
>>> work with huge vector datasets.
>>> SQLite has a spatial extension equivalent to PostGIS.
>>> It is called SpatiaLite. It has the same functionality
>>> as PostGIS. The latest version of OGR already has some
>>> basic support for SQLite, so hopefully in the near future
>>> all open source GIS will support SQLite/SpatiaLite as
>>> a datasource.
>>> However, if you are planning to to set up a spatial data
>>> infrastructure for collaborative work, you should probably
>>> choose PostgreSQL/PostGIS as your data backend, because
>>> it supports user access control and is currently better
>>> supported by open source GIS.
>>> Ben
>>> ----- Original Message -----
>>> From: "Gabriele N." <gis.gn a libero.it>
>>> To: grass-user a lists.osgeo.org
>>> Sent: Friday, February 20, 2009 5:38:48 PM GMT +00:00 GMT Britain,
>>> Ireland, Portugal
>>> Subject: [GRASS-user] GRASS 7 and SQLITE o POSTGRES
>>> Hello.
>>> I work with colleagues sharing the files (shapes .. etc) that are on a
>>> NAS
>>> server.
>>> I use ubuntu 8.10 (with GRASS locally) and my colleagues use windows.
>>> I would do this:
>>> - A GIS with all these data
>>> - Building a database (sqlite or postgres/postgis/ on NAS)
>>> - An excellent organization of the data
>>> - To enable access to data with other software (such as QGIS and gvSIG)
>>> GRASS 7 will default SQLite and therefore should be different to GRASS
>>> 6.
>>> In
>>> the sense that now GRASS 6 connects to the DB (postgres and / or sqlite)
>>> but
>>> works differently than the dbf ... or wrong?
>>> SQLite does not have the spatial component as postgis with postgres?
>>> What
>>> does this?
>>> Can you tell me the steps to follow?
>>> What do you recommend?
>>> Thanks
>>> Gabriele
>>> View this message in context:
>>> http://n2.nabble.com/GRASS-7-and-SQLITE-o-POSTGRES-tp2360247p2360247.html
>>> Sent from the Grass - Users mailing list archive at Nabble.com.
>>> grass-user mailing list
>>> http://lists.osgeo.org/mailman/listinfo/grass-user
>>> Files attached to this email may be in ISO 26300 format (OASIS Open
>>> Document Format). If you have difficulty opening them, please visit
>>> http://iso26300.info for more information.
View this message in context: http://n2.nabble.com/GRASS-7-and-SQLITE-o-POSTGRES-tp2360247p2363661.html
