[GRASS-user] problem in projection of shape files
Jamie Adams jaadfoo at gmail.com
Mon Feb 23 16:50:48 EST 2009
I would use ogr2ogr <http://www.gdal.org/ogr2ogr.html> from GDAL to
reproject using a proj4 string.  For example to wgs84:
ogr2ogr -s_srs "+proj=tmerc +lat_0=0 +lon_0=90 +k=0.9996 +x_0=500000
+y_0=-2000000 +a=6377276.345 +b=6356075.41314024 +units=m +no_defs" -t_srs
wgs84 out.shp in.shp
-Jamie
On Mon, Feb 23, 2009 at 1:19 PM, Zahid Parvez
<grassgisbangladesh at gmail.com>wrote:
> hi
> I have a shape file which I have to import in GRASS. Shape file is consists
> of a shape file, a dbf file and a prj file.
> The prj file has following information.
> PROJCS["BTM",
> GEOGCS["GCS_Everest_1830",
> DATUM["D_Everest_1830",
> SPHEROID["Everest_1830",6377299.36,300.8017]],
> PRIMEM["Greenwich",0.0],
> UNIT["Degree",0.0174532925199433]],
> PROJECTION["Transverse_Mercator"],
> PARAMETER["False_Easting",500000.0],
> PARAMETER["False_Northing",-2000000.0],
> PARAMETER["Central_Meridian",90.0],
> PARAMETER["Scale_Factor",0.9996],
> PARAMETER["Latitude_Of_Origin",0.0],
> UNIT["Meter",1.0]]
> I will be very grateful if anyone could help me to find the ESPG code and
> any other way to re-project the shape file
>  and import into GRASS.
> Best
> Md. Zahid Parvez
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20090223/f036e1ab/attachment.html
