[GRASS-user] convert r.report output to spreadsheet format
maning sambale emmanuel.sambale at gmail.com
Wed Feb 25 01:51:15 EST 2009
Thanks!
An example of the r.report output:
|              Category Information               |          |     cell|   %  |
| #|description                                   |  hectares|    count| cover|
| 1|Siquijor                                      |    31,313|   385511|  0.05|
|  |112|Broadleaf - open canopy. . . . . . . . . .|      8265|   101755| 26.39|
|  |140|Mangrove . . . . . . . . . . . . . . . . .|       173|     2125|  0.55|
|  |210|Agriculture-annual . . . . . . . . . . . .|      7370|    90737| 23.54|
|  |310|Scrub. . . . . . . . . . . . . . . . . . .|      1063|    13081|  3.39|
|  |320|Grassland. . . . . . . . . . . . . . . . .|      7185|    88460| 22.95|
|  |400|Built-up . . . . . . . . . . . . . . . . .|       103|     1270|  0.33|
|  |510|Inland water . . . . . . . . . . . . . . .|        44|      539|  0.14|
|  |  *|no data. . . . . . . . . . . . . . . . . .|      7111|    87544| 22.71|
I want converted to:
Province,land_cover_code,description,hectares,cell_count,percent_cover
I will try the cryptic awk lines.
On Wed, Feb 25, 2009 at 12:12 AM, Giovanni Pasini <jynxtor at gmail.com> wrote:
> maning sambale ha scritto:
>> Hi,
>> Looking for tips in "transforming" r.report output into a
>> "spreadsheet" like format.
> Hi,
> I use awk (change NF and the other fields $*):
> r.report -n map=gri_1000_in,dem2_idw_100_slope_rec units=h,p,c | awk 'BEGIN
> {FS="|";OFS="|"} !/---/ && NF==7 {intest=$2} NF==8 {sub(/[ .]*$/,"",$4);
> print intest, $4, $6}' > report_slope.txt
> This from a non awk expert!
> cheers,
> giovanni
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
cheers,
maning
"Freedom is still the most radical idea of all" -N.Branden
wiki: http://esambale.wikispaces.com/
blog: http://epsg4253.wordpress.com/
