[GRASS-user] categories in raster map
FAROUX STEPHANIE stephanie.faroux at meteo.fr
Thu Feb 26 08:01:44 EST 2009
>>>> On 26/02/09 11:47, FAROUX STEPHANIE wrote:
>>>>> Hello,
>>>>> I see the function r.cats which allows to read categories of a
>>>>> raster map, but how can i define these attributes? Should i pass
>>>>> by a vector map? In the database menu, it doesn't seem possible to
>>>>> add a table for a raster map.
>>>> Raster maps have categories and labels. Categories have to be
>>>> numerical, labels can be anything. Each pixel needs to have a
>>>> category value (or NULL) and optionally you can have one (and only
>>>> one) label per category value.
>>>> BTW, r.cats is now replaced by r.category.
>>>> If you want to link a cell with many attributes, you will have to
>>>> use vector grids (v.mkgrid or r.to.vect as you suggestà).
>>>> Moritz
>>> Thank you. And how do you put labels on categories please?
>>> grass-user mailing list
>>> grass-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/grass-user
>> I use r.reclass that's it?
> No, r.reclass "changes" category values, not labels.
> I think it would be better if you explained a bit more clearly what
> you want to do, i.e. what do you have and what would you like to have.
> Normally, r.category seems to be what you are looking for, using the
> rules= option.
> I do see that the man page might not be particularly clear on its
> usage (the Description part only mentions printing, not managing
> labels and the part on dynamic labels is a bit cryptic). But the
> section "Input from a file" should give you what you need.
> Moritz
Ok. I see it in the manual page of the 6.5 version.
Actually i work with the 6.2 version (i'm at office and i haven't
"control" on the installed version) and i think r.cats doesn't have this
option. But with r.reclass i achieved.
Here i have a map with integer categories values; i want to recode these
categories but keep old values as labels.
Stéphanie
