[GRASS-user] v.in.dxf lines with no elevation
Adam Dershowitz adershowitz at exponent.com
Mon Jan 5 21:20:46 EST 2009
On Jan 5, 2009, at 6:02 PM, Adam Dershowitz wrote:
> I have a dxf file that contains both lines and points.  If I import
> it into grass with v.in.dxf the lines end up at an elevation of 0,
> while the points show up correctly.  I have verified that the lines
> do in fact have an elevation by importing the dxf both into google
> sketch up and blender as a test.
> I googled around some and it seems like it used to be necessary to
> run v.in.dxf3d but I can't find that, and it appears that it was
> just incorporated into v.in.dxf, best I can tell.
> Any suggestions for getting the lines to the correct elevation?
> Thanks,
> --Adam
Also, when I do the import I get a warning "3-d data in dxf file"
