[GRASS-user] wget (corine) "landcover_tiles_v2" for greece works, but not for europe(?) [SOLVED]
Nikos Alexandris nikos.alexandris at felis.uni-freiburg.de
Mon Jan 12 18:23:23 EST 2009
On Mon, 2009-01-12 at 16:19 +0100, Nikos Alexandris wrote:
> # get GR_100K.shp which is GREEA18328I.zip [1] from [2]
> # under the column "CellCode" are listed all tiles (in this case all
> tiles which cover Greece) with their exact name.
> #v.db.connect -p
> ## if requiredδημιουργία της σύνδεσης αν δεν υφίσταται
> # db.connect driver=sqlite
> database=/geo/grassdb/ellas/laea/PERMANENT/sqlite.d
> # import GR_100K.shp
> v.in.ogr dsn=/geo/geodata/europe/GREEA18328I/GR_100K.shp
> out=eea_gr_100k --o
> # check newly imported table
> db.select eea_gr_100k
> cat|CellCode|EofOrigin|NofOrigin
> 1|100kmE51N18|5100000|1800000
> 2|100kmE51N19|5100000|1900000
> 3|100kmE52N16|5200000|1600000
> 4|100kmE52N17|5200000|1700000
> 5|100kmE52N18|5200000|1800000
> 6|100kmE52N19|5200000|1900000
> 7|100kmE52N20|5200000|2000000
> 8|100kmE53N15|5300000|1500000
> 9|100kmE53N16|5300000|1600000
> 10|100kmE53N17|5300000|1700000
> # create file with tiles-list
> db.select eea_gr_100k -c | cut -d"|" -f2 > corine_tiles_ellas
> 100kmE51N18
> 100kmE51N19
> 100kmE52N16
> 100kmE52N17
> 100kmE52N18
> 100kmE52N19
> # wget within a for loop
> for x in `cat corine_tiles_ellas`; do wget
> http://dataservice.eea.europa.eu/staticfiles/landcover_tiles_v2/$x.zip;
> done
> --2009-01-12 15:12:26--
> http://dataservice.eea.europa.eu/staticfiles/landcover_tiles_v2/100kmE51N18.zip
> Resolving dataservice.eea.europa.eu... 217.74.209.209
> Connecting to dataservice.eea.europa.eu|217.74.209.209|:80...
> connected.
> HTTP request sent, awaiting response... 200 OK
> Length: 408346 (399K) [application/x-zip-compressed]
> Saving to: `100kmE51N18.zip'
> 100%
> [============================>] 408,346     1.12M/s   in 0.3s
> 2009-01-12 15:12:27 (1.12 MB/s) - `100kmE51N18.zip' saved
> [408346/408346]
> Now, if I try to repeat this process for the whole of europe (based on
> the file Grid_ETRS89_LAEA5210_100K[3]), I only get 31KB files which are
> corrupted (?) and anyway, they are to small to carry any information.
> What could be the reason?
(Answerting to myself ;-)
It's simple. The attribute table of Grid_ETRS89_LAEA5210_100K holds lots
of "empty cells" since it covers a huge rectangular (a total of more
than 8000 boxes if I remember well).
I downloaded each country's 100k-eea-reference-grid shapefile, imported
all in grass and exported a "european non-empty" list (file attached -
around 1300 boxes). I re-run the wget-for loop and everything works
fine :-)
> [1] http://dataservice.eea.europa.eu/download.asp?id=18328&filetype=.zip
> [2] http://dataservice.eea.europa.eu/dataservice/metadetails.asp?id=760
> [3] http://dataservice.eea.europa.eu/download.asp?id=16267&filetype=.zip
100kmE50N21
100kmE51N18
100kmE51N19
100kmE51N20
100kmE51N21
100kmE51N22
100kmE52N18
100kmE52N19
100kmE52N20
100kmE52N21
100kmE42N26
100kmE42N27
100kmE43N26
100kmE43N27
100kmE44N26
100kmE44N27
100kmE45N25
100kmE45N26
100kmE45N27
100kmE45N28
100kmE46N25
100kmE46N26
100kmE46N27
100kmE46N28
100kmE46N29
100kmE47N26
100kmE47N27
100kmE47N28
100kmE47N29
100kmE48N26
100kmE48N27
100kmE48N28
100kmE47N24
100kmE48N22
100kmE48N23
100kmE48N24
100kmE49N22
100kmE49N23
100kmE49N24
100kmE50N21
100kmE50N22
100kmE50N23
100kmE50N24
100kmE37N31
100kmE38N30
100kmE38N31
100kmE39N29
100kmE39N30
100kmE39N31
100kmE40N29
100kmE40N30
100kmE40N31
100kmE53N21
100kmE53N22
100kmE53N23
100kmE53N24
100kmE54N21
100kmE54N22
100kmE54N23
100kmE54N24
100kmE55N21
100kmE55N22
100kmE55N23
100kmE55N24
100kmE56N21
100kmE56N22
100kmE56N23
100kmE56N24
100kmE56N25
100kmE57N22
100kmE57N23
100kmE57N24
100kmE58N22
100kmE58N23
100kmE58N24
100kmE40N25
100kmE40N26
100kmE40N27
100kmE41N25
100kmE41N26
100kmE41N27
100kmE42N25
100kmE42N26
100kmE42N27
100kmE43N25
100kmE43N26
100kmE63N15
100kmE63N16
100kmE64N15
100kmE64N16
100kmE64N17
100kmE65N16
100kmE65N17
100kmE44N29
100kmE44N30
100kmE45N28
100kmE45N29
100kmE45N30
100kmE45N31
100kmE46N28
100kmE46N29
100kmE46N30
100kmE46N31
100kmE47N28
100kmE47N29
100kmE47N30
100kmE47N31
100kmE48N28
100kmE48N29
100kmE48N30
100kmE49N28
100kmE49N29
100kmE49N30
100kmE38N36
100kmE39N34
100kmE39N35
100kmE39N36
100kmE40N28
100kmE40N29
100kmE40N30
100kmE40N31
100kmE40N32
100kmE40N33
100kmE40N34
100kmE40N35
100kmE40N36
100kmE41N27
100kmE41N28
100kmE41N29
100kmE41N30
100kmE41N31
100kmE41N32
100kmE41N33
100kmE41N34
100kmE41N35
100kmE41N36
100kmE42N27
100kmE42N28
100kmE42N29
100kmE42N30
100kmE42N31
100kmE42N32
100kmE42N33
100kmE42N34
100kmE42N35
100kmE43N26
100kmE43N27
100kmE43N28
100kmE43N29
100kmE43N30
100kmE43N31
100kmE43N32
100kmE43N33
100kmE43N34
100kmE43N35
100kmE44N26
100kmE44N27
100kmE44N28
100kmE44N29
100kmE44N30
100kmE44N31
100kmE44N32
100kmE44N33
100kmE44N34
100kmE44N35
100kmE45N27
100kmE45N28
100kmE45N29
100kmE45N30
100kmE45N31
100kmE45N32
100kmE45N33
100kmE45N34
100kmE45N35
100kmE46N28
100kmE46N30
100kmE46N31
100kmE46N32
100kmE46N33
100kmE46N34
100kmE46N35
100kmE41N35
100kmE41N36
100kmE41N37
100kmE41N38
100kmE42N35
100kmE42N36
100kmE42N37
100kmE42N38
100kmE43N35
100kmE43N36
100kmE43N37
100kmE43N38
100kmE44N34
100kmE44N35
100kmE44N36
100kmE44N37
100kmE44N38
100kmE45N34
100kmE45N35
100kmE46N34
100kmE46N35
100kmE46N36
100kmE49N39
100kmE49N40
100kmE50N38
100kmE50N39
100kmE50N40
100kmE50N41
100kmE51N38
100kmE51N39
100kmE51N40
100kmE51N41
100kmE52N39
100kmE52N40
100kmE52N41
100kmE52N42
100kmE53N39
100kmE53N40
100kmE53N41
100kmE14N9
100kmE14N10
100kmE15N9
100kmE15N10
100kmE15N11
100kmE15N12
100kmE16N9
100kmE16N10
100kmE16N11
100kmE16N12
100kmE17N8
100kmE17N9
100kmE17N10
100kmE17N11
100kmE18N8
100kmE18N9
100kmE18N10
100kmE18N11
100kmE19N8
100kmE19N9
100kmE19N10
100kmE19N11
100kmE20N8
100kmE20N9
100kmE20N10
100kmE20N11
100kmE21N10
100kmE26N22
100kmE26N23
100kmE26N24
100kmE27N16
100kmE27N17
100kmE27N18
100kmE27N22
100kmE27N23
100kmE27N24
100kmE27N25
100kmE28N14
100kmE28N15
100kmE28N16
100kmE28N17
100kmE28N18
100kmE28N19
100kmE28N20
100kmE28N21
100kmE28N22
100kmE28N23
100kmE28N24
100kmE28N25
100kmE29N14
100kmE29N15
100kmE29N16
100kmE29N17
100kmE29N18
100kmE29N19
100kmE29N20
100kmE29N21
100kmE29N22
100kmE29N23
100kmE29N24
100kmE29N25
100kmE30N15
100kmE30N16
100kmE30N17
100kmE30N18
100kmE30N19
100kmE30N20
100kmE30N21
100kmE30N22
100kmE30N23
100kmE30N24
100kmE31N14
100kmE31N15
100kmE31N16
100kmE31N17
100kmE31N18
100kmE31N19
100kmE31N20
100kmE31N21
100kmE31N22
100kmE31N23
100kmE31N24
100kmE32N14
100kmE32N15
100kmE32N16
100kmE32N17
100kmE32N18
100kmE32N19
100kmE32N20
100kmE32N21
100kmE32N22
100kmE32N23
100kmE32N24
100kmE33N15
100kmE33N16
100kmE33N17
100kmE33N18
100kmE33N19
100kmE33N20
100kmE33N21
100kmE33N22
100kmE33N23
100kmE33N24
100kmE34N16
100kmE34N17
100kmE34N18
100kmE34N19
100kmE34N20
100kmE34N21
100kmE34N22
100kmE34N23
100kmE35N17
100kmE35N18
100kmE35N19
100kmE35N20
100kmE35N21
100kmE35N22
100kmE36N17
100kmE36N18
100kmE36N19
100kmE36N20
100kmE36N21
100kmE36N22
100kmE37N17
100kmE37N18
100kmE37N19
100kmE37N20
100kmE37N21
100kmE38N18
100kmE38N19
100kmE38N20
100kmE38N21
100kmE39N18
100kmE39N19
100kmE47N50
100kmE47N51
100kmE48N41
100kmE48N42
100kmE48N43
100kmE48N44
100kmE48N45
100kmE48N46
100kmE48N49
100kmE48N50
100kmE48N51
100kmE49N40
100kmE49N41
100kmE49N42
100kmE49N43
100kmE49N44
100kmE49N45
100kmE49N46
100kmE49N47
100kmE49N48
100kmE49N49
100kmE49N50
100kmE49N51
100kmE49N52
100kmE49N53
100kmE50N40
100kmE50N41
100kmE50N42
100kmE50N43
100kmE50N44
100kmE50N45
100kmE50N46
100kmE50N47
100kmE50N48
100kmE50N49
100kmE50N50
100kmE50N51
100kmE50N52
100kmE50N53
100kmE51N41
100kmE51N42
100kmE51N43
100kmE51N44
100kmE51N45
100kmE51N46
100kmE51N47
100kmE51N48
100kmE51N49
100kmE51N50
100kmE51N51
100kmE52N41
100kmE52N42
100kmE52N43
100kmE52N44
100kmE52N45
100kmE52N46
100kmE52N47
100kmE52N48
100kmE52N49
100kmE53N43
100kmE53N44
100kmE53N45
100kmE53N46
100kmE53N47
100kmE54N45
100kmE31N28
100kmE31N29
100kmE32N27
100kmE32N28
100kmE32N29
100kmE33N22
100kmE33N23
100kmE33N24
100kmE33N25
100kmE33N26
100kmE33N27
100kmE33N28
100kmE33N29
100kmE34N22
100kmE34N23
100kmE34N24
100kmE34N25
100kmE34N26
100kmE34N27
100kmE34N28
100kmE34N29
100kmE34N30
100kmE35N22
100kmE35N23
100kmE35N24
100kmE35N25
100kmE35N26
100kmE35N27
100kmE35N28
100kmE35N29
100kmE35N30
100kmE36N21
100kmE36N22
100kmE36N23
100kmE36N24
100kmE36N25
100kmE36N26
100kmE36N27
100kmE36N28
100kmE36N29
100kmE36N30
100kmE36N31
100kmE37N21
100kmE37N22
100kmE37N23
100kmE37N24
100kmE37N25
100kmE37N26
100kmE37N27
100kmE37N28
100kmE37N29
100kmE37N30
100kmE37N31
100kmE38N21
100kmE38N22
100kmE38N23
100kmE38N24
100kmE38N25
100kmE38N26
100kmE38N27
100kmE38N28
100kmE38N29
100kmE38N30
100kmE38N31
100kmE39N21
100kmE39N22
100kmE39N23
100kmE39N24
100kmE39N25
100kmE39N26
100kmE39N27
100kmE39N28
100kmE39N29
100kmE39N30
100kmE40N21
100kmE40N22
100kmE40N23
100kmE40N24
100kmE40N25
100kmE40N26
100kmE40N27
100kmE40N28
100kmE40N29
100kmE41N20
100kmE41N21
100kmE41N22
100kmE41N23
100kmE41N24
100kmE41N27
100kmE41N28
100kmE41N29
100kmE42N20
100kmE42N21
100kmE42N22
100kmE43N20
100kmE43N21
100kmE43N22
100kmE51N18
100kmE51N19
100kmE52N16
100kmE52N17
100kmE52N18
100kmE52N19
100kmE52N20
100kmE53N15
100kmE53N16
100kmE53N17
100kmE53N18
100kmE53N19
100kmE53N20
100kmE53N21
100kmE54N15
100kmE54N16
100kmE54N17
100kmE54N18
100kmE54N19
100kmE54N20
100kmE54N21
100kmE55N14
100kmE55N15
100kmE55N16
100kmE55N17
100kmE55N18
100kmE55N19
100kmE55N20
100kmE55N21
100kmE56N14
100kmE56N15
100kmE56N16
100kmE56N17
100kmE56N18
100kmE56N19
100kmE56N20
100kmE56N21
100kmE56N22
100kmE57N14
100kmE57N15
100kmE57N16
100kmE57N17
100kmE57N18
100kmE57N19
100kmE57N21
100kmE58N14
100kmE58N15
100kmE58N16
100kmE58N17
100kmE58N18
100kmE59N15
100kmE59N16
100kmE59N17
100kmE60N16
100kmE45N24
100kmE46N23
100kmE46N24
100kmE46N25
100kmE47N22
100kmE47N23
100kmE47N24
100kmE47N25
100kmE47N26
100kmE48N21
100kmE48N22
100kmE48N23
100kmE48N24
100kmE48N25
100kmE48N26
100kmE49N21
100kmE49N22
100kmE49N24
100kmE49N25
100kmE50N21
100kmE50N22
100kmE50N24
100kmE50N25
100kmE47N26
100kmE47N27
100kmE48N25
100kmE48N26
100kmE48N27
100kmE49N25
100kmE49N26
100kmE49N27
100kmE49N28
100kmE50N25
100kmE50N26
100kmE50N27
100kmE50N28
100kmE51N26
100kmE51N27
100kmE51N28
100kmE52N26
100kmE52N27
100kmE52N28
100kmE28N33
100kmE28N34
100kmE29N32
100kmE29N33
100kmE29N34
100kmE29N35
100kmE29N36
100kmE30N32
100kmE30N33
100kmE30N34
100kmE30N35
100kmE30N36
100kmE30N37
100kmE31N32
100kmE31N33
100kmE31N34
100kmE31N35
100kmE31N36
100kmE31N37
100kmE32N33
100kmE32N34
100kmE32N35
100kmE32N36
100kmE32N37
100kmE33N34
100kmE33N35
100kmE27N48
100kmE27N49
100kmE27N50
100kmE27N51
100kmE28N47
100kmE28N48
100kmE28N49
100kmE28N50
100kmE28N51
100kmE29N47
100kmE29N48
100kmE29N49
100kmE29N50
100kmE29N51
100kmE30N47
100kmE30N48
100kmE30N49
100kmE30N50
100kmE31N47
100kmE31N48
100kmE31N49
100kmE31N50
100kmE32N48
100kmE32N49
100kmE32N50
100kmE40N17
100kmE40N18
100kmE40N19
100kmE40N20
100kmE40N23
100kmE40N24
100kmE40N25
100kmE41N16
100kmE41N17
100kmE41N18
100kmE41N19
100kmE41N20
100kmE41N22
100kmE41N23
100kmE41N24
100kmE41N25
100kmE42N16
100kmE42N17
100kmE42N18
100kmE42N19
100kmE42N20
100kmE42N21
100kmE42N22
100kmE42N23
100kmE42N24
100kmE42N25
100kmE43N16
100kmE43N17
100kmE43N18
100kmE43N19
100kmE43N20
100kmE43N21
100kmE43N22
100kmE43N23
100kmE43N24
100kmE43N25
100kmE43N26
100kmE44N15
100kmE44N16
100kmE44N17
100kmE44N19
100kmE44N20
100kmE44N21
100kmE44N22
100kmE44N23
100kmE44N24
100kmE44N25
100kmE44N26
100kmE45N13
100kmE45N14
100kmE45N15
100kmE45N16
100kmE45N17
100kmE45N19
100kmE45N20
100kmE45N21
100kmE45N22
100kmE45N23
100kmE45N24
100kmE45N25
100kmE45N26
100kmE46N14
100kmE46N15
100kmE46N16
100kmE46N17
100kmE46N18
100kmE46N19
100kmE46N20
100kmE46N21
100kmE46N22
100kmE46N23
100kmE46N24
100kmE46N25
100kmE46N26
100kmE47N14
100kmE47N15
100kmE47N16
100kmE47N17
100kmE47N18
100kmE47N19
100kmE47N20
100kmE47N21
100kmE47N22
100kmE48N14
100kmE48N15
100kmE48N16
100kmE48N17
100kmE48N18
100kmE48N19
100kmE48N20
100kmE48N21
100kmE49N15
100kmE49N16
100kmE49N17
100kmE49N18
100kmE49N19
100kmE49N20
100kmE49N21
100kmE50N17
100kmE50N18
100kmE50N19
100kmE50N20
100kmE51N18
100kmE49N36
100kmE49N37
100kmE50N36
100kmE50N37
100kmE51N35
100kmE51N36
100kmE51N37
100kmE52N35
100kmE52N36
100kmE52N37
100kmE52N38
100kmE53N35
100kmE53N36
100kmE53N37
100kmE49N36
100kmE49N37
100kmE49N38
100kmE49N39
100kmE50N37
100kmE50N38
100kmE50N39
100kmE51N37
100kmE51N38
100kmE51N39
100kmE52N37
100kmE52N38
100kmE52N39
100kmE53N37
100kmE53N38
100kmE53N39
100kmE54N37
100kmE54N38
100kmE50N21
100kmE50N22
100kmE50N23
100kmE51N21
100kmE51N22
100kmE51N20
100kmE51N21
100kmE52N20
100kmE52N21
100kmE52N22
100kmE53N20
100kmE53N21
100kmE53N22
100kmE54N21
100kmE38N31
100kmE38N32
100kmE39N31
100kmE39N32
100kmE39N33
100kmE39N34
100kmE40N30
100kmE40N31
100kmE40N32
100kmE40N33
100kmE40N34
100kmE41N32
100kmE41N33
100kmE41N34
100kmE40N39
100kmE40N40
100kmE40N41
100kmE40N42
100kmE40N43
100kmE41N38
100kmE41N39
100kmE41N40
100kmE41N41
100kmE41N42
100kmE41N43
100kmE41N44
100kmE42N38
100kmE42N39
100kmE42N40
100kmE42N41
100kmE42N42
100kmE42N43
100kmE42N44
100kmE42N45
100kmE43N39
100kmE43N40
100kmE43N41
100kmE43N42
100kmE43N43
100kmE43N44
100kmE43N45
100kmE43N46
100kmE43N47
100kmE44N39
100kmE44N40
100kmE44N41
100kmE44N42
100kmE44N43
100kmE44N44
100kmE44N45
100kmE44N46
100kmE44N47
100kmE44N48
100kmE44N49
100kmE44N50
100kmE45N45
100kmE45N46
100kmE45N47
100kmE45N48
100kmE45N49
100kmE45N50
100kmE45N51
100kmE46N48
100kmE46N49
100kmE46N50
100kmE46N51
100kmE46N52
100kmE47N50
100kmE47N51
100kmE47N52
100kmE47N53
100kmE48N51
100kmE48N52
100kmE48N53
100kmE48N54
100kmE49N51
100kmE49N52
100kmE49N53
100kmE49N54
100kmE50N52
100kmE50N53
100kmE50N54
100kmE51N52
100kmE51N53
100kmE45N32
100kmE45N33
100kmE45N34
100kmE46N30
100kmE46N31
100kmE46N32
100kmE46N33
100kmE46N34
100kmE47N30
100kmE47N31
100kmE47N32
100kmE47N33
100kmE47N34
100kmE47N35
100kmE48N30
100kmE48N31
100kmE48N32
100kmE48N33
100kmE48N34
100kmE48N35
100kmE49N29
100kmE49N30
100kmE49N31
100kmE49N32
100kmE49N33
100kmE49N34
100kmE49N35
100kmE50N29
100kmE50N30
100kmE50N31
100kmE50N32
100kmE50N33
100kmE50N34
100kmE50N35
100kmE51N29
100kmE51N30
100kmE51N31
100kmE51N32
100kmE51N33
100kmE51N34
100kmE51N35
100kmE52N29
100kmE52N30
100kmE52N31
100kmE52N32
100kmE52N33
100kmE52N34
100kmE52N35
100kmE53N31
100kmE53N32
100kmE8N27
100kmE8N28
100kmE9N27
100kmE9N28
100kmE10N24
100kmE10N25
100kmE10N26
100kmE10N27
100kmE10N28
100kmE11N24
100kmE11N25
100kmE11N26
100kmE12N21
100kmE12N22
100kmE12N23
100kmE12N24
100kmE12N25
100kmE13N21
100kmE13N22
100kmE13N23
100kmE13N24
100kmE17N14
100kmE17N15
100kmE18N11
100kmE18N12
100kmE18N14
100kmE18N15
100kmE25N17
100kmE25N18
100kmE25N19
100kmE25N20
100kmE26N16
100kmE26N17
100kmE26N18
100kmE26N19
100kmE26N20
100kmE26N21
100kmE27N16
100kmE27N17
100kmE27N18
100kmE27N19
100kmE27N20
100kmE27N21
100kmE27N22
100kmE27N23
100kmE28N18
100kmE28N19
100kmE28N20
100kmE28N21
100kmE28N22
100kmE29N20
100kmE29N21
100kmE29N22
100kmE51N25
100kmE51N26
100kmE51N27
100kmE52N24
100kmE52N25
100kmE52N26
100kmE52N27
100kmE52N28
100kmE53N23
100kmE53N24
100kmE53N25
100kmE53N26
100kmE53N27
100kmE53N28
100kmE54N23
100kmE54N24
100kmE54N25
100kmE54N26
100kmE54N27
100kmE54N28
100kmE54N29
100kmE55N23
100kmE55N24
100kmE55N25
100kmE55N26
100kmE55N27
100kmE55N28
100kmE55N29
100kmE56N24
100kmE56N25
100kmE56N26
100kmE56N27
100kmE56N28
100kmE56N29
100kmE57N24
100kmE57N25
100kmE57N26
100kmE57N27
100kmE57N28
100kmE58N24
100kmE58N25
100kmE58N26
100kmE50N22
100kmE50N23
100kmE50N24
100kmE50N25
100kmE50N26
100kmE51N21
100kmE51N22
100kmE51N23
100kmE51N24
100kmE51N25
100kmE51N26
100kmE52N21
100kmE52N22
100kmE52N23
100kmE52N24
100kmE52N25
100kmE53N22
100kmE53N23
100kmE53N24
100kmE43N37
100kmE43N38
100kmE43N39
100kmE43N40
100kmE44N35
100kmE44N36
100kmE44N37
100kmE44N38
100kmE44N39
100kmE44N40
100kmE44N41
100kmE44N42
100kmE44N43
100kmE44N44
100kmE44N45
100kmE44N46
100kmE45N35
100kmE45N36
100kmE45N37
100kmE45N38
100kmE45N39
100kmE45N40
100kmE45N41
100kmE45N42
100kmE45N43
100kmE45N44
100kmE45N45
100kmE45N46
100kmE45N47
100kmE45N48
100kmE45N49
100kmE45N50
100kmE46N35
100kmE46N36
100kmE46N37
100kmE46N38
100kmE46N39
100kmE46N40
100kmE46N41
100kmE46N42
100kmE46N43
100kmE46N44
100kmE46N45
100kmE46N46
100kmE46N47
100kmE46N48
100kmE46N49
100kmE46N50
100kmE47N35
100kmE47N36
100kmE47N37
100kmE47N38
100kmE47N39
100kmE47N40
100kmE47N41
100kmE47N42
100kmE47N43
100kmE47N44
100kmE47N45
100kmE47N46
100kmE47N47
100kmE47N48
100kmE47N49
100kmE47N50
100kmE47N51
100kmE48N36
100kmE48N37
100kmE48N38
100kmE48N39
100kmE48N40
100kmE48N41
100kmE48N42
100kmE48N43
100kmE48N44
100kmE48N45
100kmE48N46
100kmE48N47
100kmE48N48
100kmE48N49
100kmE48N50
100kmE48N51
100kmE49N36
100kmE49N37
100kmE49N38
100kmE49N39
100kmE49N40
100kmE49N41
100kmE49N45
100kmE49N46
100kmE49N47
100kmE49N48
100kmE49N49
100kmE49N50
100kmE45N24
100kmE45N25
100kmE45N26
100kmE46N24
100kmE46N25
100kmE46N26
100kmE47N24
100kmE47N25
100kmE47N26
100kmE48N26
100kmE48N27
100kmE48N28
100kmE48N29
100kmE49N27
100kmE49N28
100kmE49N29
100kmE50N28
100kmE50N29
100kmE51N28
100kmE51N29
100kmE52N28
100kmE52N29
100kmE56N19
100kmE56N20
100kmE56N21
100kmE56N22
100kmE57N18
100kmE57N19
100kmE57N20
100kmE57N21
100kmE57N22
100kmE58N16
100kmE58N17
100kmE58N18
100kmE58N19
100kmE58N20
100kmE58N21
100kmE58N22
100kmE59N16
100kmE59N17
100kmE59N18
100kmE59N19
100kmE59N20
100kmE59N21
100kmE59N22
100kmE60N16
100kmE60N17
100kmE60N18
100kmE60N19
100kmE60N20
100kmE60N21
100kmE60N22
100kmE61N16
100kmE61N17
100kmE61N18
100kmE61N19
100kmE61N20
100kmE61N21
100kmE61N22
100kmE61N23
100kmE62N17
100kmE62N18
100kmE62N19
100kmE62N20
100kmE62N21
100kmE62N22
100kmE62N23
100kmE62N24
100kmE63N17
100kmE63N18
100kmE63N19
100kmE63N20
100kmE63N21
100kmE63N22
100kmE63N23
100kmE63N24
100kmE64N17
100kmE64N18
100kmE64N19
100kmE64N20
100kmE64N21
100kmE64N22
100kmE64N23
100kmE64N24
100kmE65N18
100kmE65N19
100kmE65N20
100kmE65N21
100kmE65N22
100kmE65N23
100kmE65N24
100kmE66N18
100kmE66N19
100kmE66N20
100kmE66N21
100kmE66N22
100kmE66N23
100kmE66N24
100kmE67N19
100kmE67N20
100kmE67N21
100kmE67N22
100kmE67N23
100kmE67N24
100kmE68N19
100kmE68N20
100kmE68N21
100kmE68N22
100kmE68N23
100kmE68N24
100kmE68N25
100kmE69N20
100kmE69N21
100kmE69N22
100kmE69N23
100kmE69N24
100kmE69N25
100kmE69N26
100kmE70N21
100kmE70N22
100kmE70N23
100kmE70N24
100kmE70N25
100kmE70N26
100kmE71N21
100kmE71N22
100kmE71N23
100kmE71N24
100kmE71N25
100kmE72N22
100kmE72N23
100kmE72N24
100kmE72N25
100kmE73N22
100kmE29N15
100kmE31N30
100kmE31N31
100kmE31N35
100kmE31N36
100kmE32N30
100kmE32N31
100kmE32N32
100kmE32N33
100kmE32N34
100kmE32N35
100kmE32N36
100kmE32N37
100kmE32N38
100kmE32N39
100kmE32N40
100kmE33N30
100kmE33N31
100kmE33N32
100kmE33N33
100kmE33N34
100kmE33N35
100kmE33N36
100kmE33N37
100kmE33N38
100kmE33N39
100kmE33N40
100kmE34N30
100kmE34N31
100kmE34N32
100kmE34N33
100kmE34N34
100kmE34N35
100kmE34N36
100kmE34N37
100kmE34N38
100kmE34N39
100kmE34N40
100kmE34N41
100kmE35N30
100kmE35N31
100kmE35N32
100kmE35N33
100kmE35N34
100kmE35N35
100kmE35N36
100kmE35N37
100kmE35N38
100kmE35N39
100kmE35N40
100kmE35N41
100kmE36N30
100kmE36N31
100kmE36N32
100kmE36N33
100kmE36N34
100kmE36N35
100kmE36N36
100kmE36N37
100kmE36N38
100kmE36N39
100kmE36N40
100kmE36N41
100kmE36N42
100kmE37N30
100kmE37N31
100kmE37N32
100kmE37N33
100kmE37N34
100kmE37N35
100kmE37N40
100kmE37N41
100kmE37N42
100kmE38N32
100kmE38N33
