[GRASS-user] Character encoding problem
Jana Krajcovicova jkrajc at gmail.com
Wed Jan 21 05:15:39 EST 2009
CORRECTION:
It is still desirable to change the character encoding directly in the .dbf
file after import.
Reason is that setting truetype and character encoding  using
d.font.freetype only affects display commands, but reading database (e.g.,
using db.select) is still scrambled.
Maybe there is an environmental variable in GRASS which can be used to
change the default UTF8 encoding? But I would say that it is better to use
OpenOffice to change .dbf file encoding in single cases.
Jana
On Wed, Jan 21, 2009 at 9:22 AM, Jana Krajcovicova <jkrajc at gmail.com> wrote:
> That's correct Glynn, I've just tested that. The trick is as simple as to
> use *Truetype* font and set charset to the encoding used in the input
> vector map (Apparently, my GRASS was not built to use iconv() :-)
> Anyway, GRASS is so nice, thanks to all of you :-)
> Jana
>> I can't comment on GDAL/OGR issues, but the display library will
>> accept data in any encoding recognised by iconv[1] when using FreeType
>> fonts. You just need to specify the encoding via the charset= option.
>> [1] Provided that GRASS was built to use iconv(); this is
>> autodetected. Otherwise, text is treated as ISO-8859-1.
>> Glynn Clements <glynn at gclements.plus.com>
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20090121/df3d1319/attachment-0001.html
