R: Re: [GRASS-user] problems with v.edit
Martin Landa landa.martin at gmail.com
Wed Jan 21 06:11:00 EST 2009
2009/1/21 chiaraercoli at tiscali.it <chiaraercoli at tiscali.it>:
> v.edit map=ret_125
> tool=select  thresh=$ris_edit coords=$x,$y
> the point is 6 meters far from the line and I used a threshold of
> 100 meters.
so should I understand that result of tool=select no feature is found?
Can you send me sample data?
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
