[GRASS-user] v.in.ogr
Markus Neteler neteler at osgeo.org
Fri Jan 23 18:27:48 EST 2009
On Fri, Jan 23, 2009 at 11:38 PM, Martin Schweizer
<schweizermartin at students.unibe.ch> wrote:
> Hi.
> I have the following problem with a Shape-file. First the history: I
> imported once a ascii-file, then i exported it to a shape-file. Then I
> changed some values with QGis and now I would like to re-import the file
> (shp). So I used the command v.in.ogr.
> v.in.ogr    {dsn=/home/....../Städte Noricum Romanum5.shp}
> output=Staedte_Noricum min_area=0.0001 snp=-1
> And the Result is (I tried to translate it to english):
> Spaltenname wurde geändert: 'cat' -> 'cat_'  (in english: Column-name
> changed: 'cat' -> 'cat_')
> DBMI-DBF driver error:
> Column 'cat_' already exists (duplicate name)
> Cannot create table.
> Error in db_execute_immediate()
> Kann Tabelle nicht erzeugen (in english: Could not create table):
> 'create table Staedte_Noricum2 (cat integer, cat_ integer, cat_ integer,
> dbl_1 double precision, dbl_2 double precision, str_1 varchar ( 80 ),
> str_2 varchar ( 80 ), str_3 varchar ( 80 ), str_4 varchar ( 80 ), str_6
> varchar ( 80 ), int_1 integer)'
> So: What can I do to import this Shape-file correctly?
you have basically two options:
- either remove the superfluous cat_ column in the DBF file (Openoffice can
  do that, see
   http://grass.osgeo.org/wiki/Openoffice.org_with_SQL_Databases#DBF_files_.28OpenOffice.org_2.x.29
- or use the cnames option of v.in.ogr to assign new column names on the fly
  http://grass.osgeo.org/gdp/html_grass64/v.in.ogr.html
Markus
