[GRASS-user] I: problems with v.edit
chiaraercoli at tiscali.it chiaraercoli at tiscali.it
Tue Jan 27 11:43:58 EST 2009
2009/1/20 chiaraercoli at tiscali.it <chiaraercoli at tiscali.it>:
> I have a problem with v-edit.
> I have to break a vector line
> into two parts near a point. I gave this command:
> v.edit map=ret_125
> layer=1 type=line tool=break thresh=$ris_edit coords=$x,$y snap=no
> where " $ris_edit "  depends on the resolution of the DEM raster
map,
> "$x" and "$y" are the coordinates of the point.
are you sure that threshold value is enough to select vector feature
which you want to break?
v.edit map=ret_125 tool=select  thresh=$ris_edit coords=$x,$y
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.
cz/~landa
v.edit map=ret_125 tool=select  thresh=100 coords=$x,$y
I send you the line, ret_125,  and the point, punto_minimo.
Thanks for all,
  Chiara .
     __________________________________________________________Regali di San Valentino. Solo su Tiscali Shoppinghttp://shopping.tiscali.it/c-100492023-regali-per-san-valentino.html
Type: application/x-zip-compressed
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20090127/feda9159/punto_minimo.bin
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20090127/feda9159/ret_125.bin
