[GRASS-user] r.in.wms issues
Adam Dershowitz adershowitz at exponent.com
Tue Jan 27 16:50:44 EST 2009
I am trying to use r.in.wms to get elevation data from
wms.jpl.nasa.gov, but I have been running into two different
problems.  I have been using the gui on a mac with 6.3, although I
also tried 6.4 RC2 and got similar results.  The files do download but
then I can't seem to work with them properly.  I have tried geotiff
and png.  I have tried a bunch of other combinations as well.
The first problem seems to be with how temporary files are being named
so that patching is not working properly.  Here is the command that is
being generated by the gui:
r.in.wms output=elev_us_ned2 mapserver=wms.jpl.nasa.gov/wms.cgi
layers=us_ned format=png wmsquery=version=1.1.1 maxcols=1024
maxrows=1024 {wgetoptions=-c -t 5 -nv} {curloptions=-C - --retry 5 -s -
S} method=cubic v=1
This is followed by this long list of errors:
Calculating tiles
Requesting 2 tiles.
Downloading tiles
Tile already downloaded
All tiles downloaded successfully
Creating output file that is 972P x 558L.
Processing input file /Users/dersh/grass/wms_download/
elev_us_ned2__0.png.
Using band 2 of source image as alpha.
0...10...20...30...40...50...60...70...80...90...100 - done.
Invalid map <elev_us_ned2_tile_0_tmp.alpha>
Parse error
Raster map <elev_us_ned2_tile_0.1> not found
Parse error
Raster map <elev_us_ned2_tile_0.2> not found
Illegal filename. Character <
 > not allowed.
 > not allowed.
 > not allowed.
Raster map <elev_us_ned2_tile_0_tmp.1
elev_us_ned2_tile_0_tmp.2> not found
 > not allowed.
raster: couldn't be removed
 > not allowed.
header: couldn't be removed
 > not allowed.
category: couldn't be removed
 > not allowed.
color: couldn't be removed
 > not allowed.
history: couldn't be removed
 > not allowed.
misc: couldn't be removed
 > not allowed.
fcell: couldn't be removed
 > not allowed.
g3dcell: couldn't be removed
 > not allowed.
colr2/PERMANENT: couldn't be removed
elev_us_ned2_tile_0_tmp.2> nothing removed
Creating output file that is 971P x 560L.
elev_us_ned2__1.png.
Invalid map <elev_us_ned2_tile_1_tmp.alpha>
Parse error
Raster map <elev_us_ned2_tile_1.1> not found
Parse error
Raster map <elev_us_ned2_tile_1.2> not found
 > not allowed.
 > not allowed.
 > not allowed.
Raster map <elev_us_ned2_tile_1_tmp.1
elev_us_ned2_tile_1_tmp.2> not found
 > not allowed.
 > not allowed.
 > not allowed.
 > not allowed.
 > not allowed.
 > not allowed.
 > not allowed.
 > not allowed.
 > not allowed.
elev_us_ned2_tile_1_tmp.2> nothing removed
Patching [.1] channel
r.patch - elev_us_ned2_tile_0.1 not found
r.patch - elev_us_ned2_tile_1.1 not found
One or more input maps not found
<elev_us_ned2_tile_0.1> nothing removed
<elev_us_ned2_tile_1.1> nothing removed
Patching [.2] channel
r.patch - elev_us_ned2_tile_0.2 not found
r.patch - elev_us_ned2_tile_1.2 not found
<elev_us_ned2_tile_0.2> nothing removed
<elev_us_ned2_tile_1.2> nothing removed
Raster map <elev_us_ned2> not found in current mapset
The odd thing is that I am left with four temporary maps in the
mapset:  elev_us_ned2_tile_0_tmp.1 elev_us_ned2_tile_0_tmp.2
elev_us_ned2_tile_1_tmp.1 elev_us_ned2_tile_1_tmp.1  so it seems that
the script can't find these maps for some reasons.
The second problem, that might or might not be related, is that if I
open the temporary files, there is a "slot" between them.  It appears
as though they just don't line up properly.  Instead they are at an
angle to each other.  The tiles that are being selected are a top and
bottom tile.  They join at the right edge, but at the left edge there
is a gap.  So I am ending up with a black triangle through the middle
of the image.  Perhaps I have done something wrong so that the tile
selection code is not working correctly.
I am using a UTM projection with an nad83 datum.
Perhaps this second problem is something that should be taken care of
by the patching that is not happening because of the first problem?
Anyway, help would be greatly appreciated.
Thanks,
--Adam
