[GRASS-user] compile grass gdal from svn
Paolo Craveri pcraveri at gmail.com
Thu Jan 29 14:48:30 EST 2009
Hi Nikos
2009/1/29 Nikos Alexandris <nikos.alexandris at felis.uni-freiburg.de>:
> On Thu, 2009-01-29 at 20:11 +0100, Paolo Craveri wrote:
> I don't remember facing this error. Are you 100% you removed libgdal
> from Ubuntu repositories?
> # sudo apt-get purge libgdal1-1.5.0
Il pacchetto libgdal1-1.5.0 non è installato, quindi non è stato rimosso
(=Nothing to remove)
> Also, "sudo make distclean" before re-compiling?
Yes
> Maybe try to remove manually everything that "is" GDAL?
e.g.:
locate gdal-config
/usr/local/gdal/bin/gdal-config
/usr/local/src/gdal/apps/gdal-config
/usr/local/src/gdal/apps/gdal-config-inst
/usr/local/src/gdal/apps/gdal-config.in
/usr/local/src/gdal/apps/.svn/prop-base/gdal-config.in.svn-base
/usr/local/src/gdal/apps/.svn/text-base/gdal-config.in.svn-base
I find only files compiled from source.
ciao
Paolo C.
Lat. 44° 39' 11.08'' N  Long. 7° 23' 25.26'' E
