[GRASS-user] some problems in grass622 (ubuntu binaries)
Ahmet Temiz temiz at deprem.gov.tr
Sat Jan 31 13:50:16 EST 2009
thank you again
I compiled and installed grass6.4 from source without any error.
But when I ran import vector module for "shp" format.
Some errors occurred.
I am thinking there are some incompatibilities between ubuntu8 and grass
( both binary and source version).
I have been using grass63 on ubuntu7 without encountering any problems
in a different machine.
regards
On Sat, 31 Jan 2009 17:54:01 +0100, Nikos Alexandris wrote
> On Thu, 2009-01-29 at 13:00 +0100, Nikos Alexandris wrote:
> > On Thu, 2009-01-29 at 13:31 +0200, orkun wrote:
> > > thank you
> > > As far as I see from the url address you have
> > > given there is similar problem with GRASS 6.4.0RC2.
> > > regards
> > Orkun,
> > give it a try to get latest stuff. You'll see it probably will work.
> > BTW, which version of gdal do you have installed currently?
> > Nikos
> Orkun,
> my apologies for returning in this post. I see (in another thread) that
> you try to compile grass70 (=grass_trunk). I was not very clear when
> I wrote "try to get latest stuff".
> If you want a "workable+safe" grass installation then you should
> probably get latest grass64 or grass65(=grass6_devel). I think that
> developers will agree that grass7 is still under "heavy development".
> (Or maybe I am wrong... ?)
> I have no problems compiling grass63, grass64 and grass65 under Ubuntu
> (64-bit). However, grass70 is changing quite fast and some times
> there are problems.
> Kind regards, Nikos
> This message has been scanned for viruses and
> dangerous content by MailScanner, and is
> believed to be clean.
Open WebMail Project (http://openwebmail.org)
