[GRASS-user] r.terraflow error for ASTER DEM.
Sun Jul 5 09:35:44 EDT 2009
Markus Neteler wrote:
> >> 3. The default value of /var/tmp is inappropriate for Windows. It
> >> should probably use the TMP or TEMP environment variables. There
> >> probably won't be a specific directory which will be writable by all
> >> users.
> Ok, but the current default fails for sure. Personally I still think that
> the current mapset is a more appropriate default.
> We should change on Windows at least to a "more likely" directory.
> Which?
	G_convert_dirseps_from_host(G_store(getenv("TEMP")));
