[GRASS-user] v.proj help
Nikos Alexandris nikos.alexandris at felis.uni-freiburg.de
Thu Jul 23 09:09:50 EDT 2009
On Thu, 2009-07-23 at 05:45 -0700, Gustavo Espinoza wrote:
> Hi,
> I am trying to make a map of points from a CSV file. I have imported the
> file using v.in.ascii and the map displays correctly. My problem is that it
> uses a different coordinate system than another map that I am trying to
> incorporate it with. I tried to reproject the point map to my other map
> using v.proj but when I display the both of them together they are still in
> different coordinate systems. I don't know if I am going about this the
> wrong way or if there is a step I am missing. I would greatly appreciate any
> response as this has been the source of my frustration. Thank you,
> Gustavo Espinoza
Hi Gustavo!
Import your point vector map (the way you did but) in a (grass-)location
defined by its coordinate reference system.
Then reproject (v.proj) the other vector map from "its" location to the
location you created for the point map. Or the other way,
"pull" (=reproject) the point map to the other location.
If you already did that, then maybe the maps are not meant to coincide
since you can define a grass-location by one and only one coordinate
reference system.
All the best, Nikos
