[GRASS-user] r.watershed crashing grass.
Nikos Alexandris nikos.alexandris at felis.uni-freiburg.de
Sat Jul 25 06:07:10 EDT 2009
Milton Cezar Ribeiro wrote:
> > On several trying the system goes only up to 3GB, but I have 6Gb.
Markus Metz wrote:
> is grass compiled as 32bit or 64bit? 32bit applications can't use all
> 6GB of memory, only up to about 3GB.
Milton,
you mention you have 6GB of RAM. I assume that you know a 64-bit
Operating System (besides the applications being 64-bit) is required to
break the 3GB RAM limit.
* If you bought the machine with 6GB already equipped then they _must_
have installed the 64-bit version of sVista [*]. Then follow Markus'
suggestions.
* If you did a RAM upgrade by yourself (e.g. from 2GB to 6GB) then did
you check that you have a 64-bit sVista?
Nikos
[*] svista means in greek "erase them" ;-p
