[GRASS-user] r.watershed crashing grass.
Sun Jul 26 02:32:24 EDT 2009
Markus Neteler wrote:
> > In fact I have a dell machine, with Vista 64bits that came with the machine.
> > I compiled grass 64 svn using Msys. Is there a way of I know if my grass are
> > running with 64bits? By the way, what I need to change to have sure that
> > grass was compiled to 64bits?
> Did you enable it?
> --enable-64bit
> for configure...
That switch doesn't do anything on Windows. Or on Linux, for that
matter. It is only used on (some versions of) AIX, HP/UX, Irix, and
If you want 64-bit Windows executables, you would need 64-bit versions
of gcc and binutils.
