[GRASS-user] announcement of strahler stream order analysis
Carlos Grohmann carlos.grohmann at gmail.com
Mon Jul 27 10:50:03 EDT 2009
This is a module I've been looking for a long time.
compilation went OK, but when I run it:
GRASS 6.5.svn (itarare_250k):~ > r.stream
too many nested evaluations (infinite loop?)
    (procedure "Gronsole::add_data_tag" line 4)
    invoked from within
"Gronsole::add_data_tag $path $ci out"
    (procedure "Gronsole::readout" line 15)
    invoked from within
"Gronsole::readout $path $ci $mark $fh"
    invoked from within
"if [eof $fh] {
                Gronsole::readeof $path $ci $mark $fh
                Gronsole::done_command $path $ci
        } else {
    (procedure "Gronsole::file_callback" line 2)
    invoked from within
"Gronsole::file_callback .nb.fOutput.gronsole 1 cmdinsert1 file6"
and then it hangs...
cheers
Carlos
2009/7/26 Jarek Jasiewicz <jarekj at amu.edu.pl>:
> Hi list!
> I just finish first version of new grass module r.stream. Module is regular
> Grass module, written in C an has no addational dependencies. It was
> compiled with GRASS65 devel  downloaded in last  two week. Source code you
> can find here:
> http://heretic.livenet.pl/heretic/r.stream.tar.gz
> Module compiles and seems to work. Analysis was tested only on one dataset.
> To compile it copy r.streams directory to your grassXX../raster/  cd
> r.stream run make and make install
> What module calculate:
> - strahler stream order
> - shreeve stream magnitude
> - class of topological elements of drainage networks
> Module use r.watershed outputs: SDF flow direction and SDF stream network.
> Analysis of r.stream shall be run on same regions setings as r.watershed. If
> no, run g.region rast=your_dir_file first. For now module do not check if
> region and rasters are identical. It is planned to add in nearest feature.
> It also do not check if dirs and streams are SDF result. Threre are no
> addational description. It will be added after testing.
> It works only on cells data. Floating points data are not allowed (and have
> no sense).
> Module is quite fast. 3000 x3000 cells all three analysis runs no more than
> 30 s. on AMD 3800 2GB, Ubuntu 8.04
> Module is part of comprehensive project which will add full Horton analysis
> and some addational terrrains analysis to Grass. More details in the
> feature. Any cooperation is welcome. The next module I plan is directional
> vectorisation of stream network.
> For now module is available only form web address pointed below. After
> testing and removing critical errors it will be added to grass add-ons (or
> maybe to main branch?).
> Any coments, improvements and critics is very welcome.
> More advanced Grass developers: Please check my code. Its funny, but I don't
> know C.
> General code is based on GRASS r.topindex module (by Keith Beven and Huidae
> Cho, strongly modified)
> Strahler stream order algorithm from Saga GIS (by Victor Olaya, modified)
> Shreeve stream magnitude and class of topological network are my own ideas
> Test and enjoy.
> Jarek Jasiewicz
> Adam Mickiewicz University, Poznan
> Geoecology and Geoinformation Institute
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Carlos Henrique Grohmann - Geologist D.Sc.
a.k.a. Guano - Linux User #89721
ResearcherID: A-9030-2008
http://digitalelevation.blogspot.com
http://www.igc.usp.br/pessoais/guano
_________________
Can’t stop the signal.
