[GRASS-user] Can I just get rid of Wish?
William Kyngesburye woklist at kyngchaos.com
Mon Jun 8 21:45:41 EDT 2009
When you say X11, I assume you mean no GUI, or maybe the GUI in X11?
Note, there are 2 different GUIs now, and on OSX, 2 variations of one:
TclTk X11 - works with an X11 TclTk 8.4+.  This requires you to
compile and install your own TclTk.  I used to include one in the
application, but not since we got it working with Aqua
TclTk Aqua - as the warning implies, this needs TclTk 8.5+.  The
readme says where to find an installer.  This one is preferred.
wxPython.  This is included in the application.
Note 1: the TclTk NVIZ is built to use TclTk Aqua 8.5 and won't run
with 8.4 of any form.
Note 2: the application startup tries to locate TclTk in some default
locations and of forms in the following order:
TclTk 8.5 Aqua
TclTk 8.5 X11
TclTk 8.4 X11
Anyways, after GRASS starts and Wish fails, type in the Terminal:
g.gisenv set=GRASS_GUI=text
Thereafter GRASS won't try to start the TclTk GUI.
On Jun 8, 2009, at 6:49 PM, Michael Margolis wrote:
> Hi all
> I have GRASS-6.4 working fine on a Mac laptop, where it opens X11.
> I've
> installed it on a desktop, where it insists on opening Wish, and then
> malfunctions. There is a" Warning: TclTk Aqua 8.4 unsupported" in the
> Terminal window as it opens. Then an allegation that my projection
> field is
> missing when I run, for example, g.region, and some similar errors.
> This is with Spearfish, the exact same files working on the laptop.
> Any ideas? Can I just rid of Wish and get the desktop to use X11?
> Thanks,
> Michael
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"I ache, therefore I am.  Or in my case - I am, therefore I ache."
- Marvin
